Thermostat operation on a six conversion, Still trying to suss out the overheating issue, might be found? |
davebrossi |
Jul 16 2017, 11:20 AM
Member Group: Members Posts: 52 Joined: 6-December 11 From: Idaho Falls, Idaho Member No.: 13,868 Region Association: None |
I tried very hard to get my 914 to Parade, but no matter what we tried, I couldn't stop the motor from reaching temperatures of doom. While I did make it to Parade, the car did not. While there, the theory arose that maybe the thermostat on the 6 had stopped functioning correctly. I just pulled it, cleaned it up, and carried out a boiling test. Hoping someone might be able to tell me if it's functioning correctly or if this is the source of the obstruction to oil flow.
Also worth noting, the 'warm up' time it took to reach 210 was 15-30 minutes. Anyhow, picture time! (IMG:style_emoticons/default/piratenanner.gif) The following four photos were at 'boiling' (212 at least) At partial cool down (within five minutes of removing the thermostat from boiling water) As an addendum; I have a laser thermometer so I had plenty of fun chasing after various temperature readings. I do not have the traditional 911 front mounted oil cooler (and the second thermostat associated with it) and opted for a simplified aux oil cooler with switch controlled electric fan. The difference in temp between oil entering and leaving the aux cooler is significant, I do not believe the car is unable to cool oil in normal conditions, but something changed when I dropped the motor. I've checked all the external oil lines and nothing appears wrong. No lines are touching the exhaust headers, and to test the theory that I had installed the engine rubber with gaps I made certain to seal every stretch off with high temp tape before a run. No change. |
IronHillRestorations |
Jul 17 2017, 08:28 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
As I understand the thermostat should be fully open at 210. What kind of oil lines? I have seen braided stainless that had collapsed internally and was totally closed, but the hose looked fine
davebrossi |
Jul 17 2017, 09:02 AM
As I understand the thermostat should be fully open at 210. What kind of oil lines? I have seen braided stainless that had collapsed internally and was totally closed, but the hose looked fine Hi Perry; they are braided stainless steel and that is a distinct possibility. In fact if the thermostat doesn't work out, that is my next point of focus. Looking at the design of the thermostat I keep thinking the large output should open completely at 210. As for the plumbing of the oil lines the oil routes from tank to engine, engine to aux cooler and aux cooler over the top of the transaxle to the oil tank. The fan/aux cooler design implemented has a five years onwards development cycle. the testbed 914-6 with the installed aux cooler system has run without any instances of overheating in 100 degree plus summers in Dallas. Brad at 914 ltd did the install. |
gms |
Jul 17 2017, 09:11 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:26 PM |
