Running really rich, 1973 1.7 FI |
tbone1819 |
Jul 18 2017, 03:06 PM
Newbie Group: Members Posts: 26 Joined: 1-February 17 From: Lynbrook NY Member No.: 20,800 Region Association: North East States |
Ok,
So my 73 was running great until it slowly started to go down hill. Car would not start after it was running/driving for a while but the next day would fire right up. Recenltly changed the oil that was completly diluted with gasoline. WTF?? |
BeatNavy |
Jul 19 2017, 04:16 PM
Fuel pressure is not the issue then (it's probably low by a PSI - I think 28 PSI is spec).
Are you saying that you can disconnect the fuel pump relay (or connector) at the relay board and the car will start/run after initially turning the key and priming the fuel pump? Please explain in more detail. How long does it run that way? Once you prime the pump the fuel is going to be pressurized for at least a short period of time even if the pump isn't running, but it will bleed out quickly. Not sure why you disconnected fuel pump, but you still need to: 1. Verify MPS holds vacuum. 2. CHT is working properly and is connected to wiring harness properly. 3. Try with CSV disconnected. |
tbone1819 |
Jul 19 2017, 04:22 PM
Fuel pressure is not the issue then (it's probably low by a PSI - I think 28 PSI is spec). Are you saying that you can disconnect the fuel pump relay (or connector) at the relay board and the car will start/run after initially turning the key and priming the fuel pump? Please explain in more detail. How long does it run that way? Once you prime the pump the fuel is going to be pressurized for at least a short period of time even if the pump isn't running, but it will bleed out quickly. Not sure why you disconnected fuel pump, but you still need to: 1. Verify MPS holds vacuum. 2. CHT is working properly and is connected to wiring harness properly. 3. Try with CSV disconnected. The car runs for 1-2 seconds after being primed and then diconected. |
BeatNavy |
Jul 19 2017, 04:25 PM
Fuel pressure is not the issue then (it's probably low by a PSI - I think 28 PSI is spec). Are you saying that you can disconnect the fuel pump relay (or connector) at the relay board and the car will start/run after initially turning the key and priming the fuel pump? Please explain in more detail. How long does it run that way? Once you prime the pump the fuel is going to be pressurized for at least a short period of time even if the pump isn't running, but it will bleed out quickly. Not sure why you disconnected fuel pump, but you still need to: 1. Verify MPS holds vacuum. 2. CHT is working properly and is connected to wiring harness properly. 3. Try with CSV disconnected. The car runs for 1-2 seconds after being primed and then diconected. Ok, that sounds normal then. Your fuel system is pressurized when you prime the pump. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:16 AM |
