I broke a rear trailing arm at the track!, Holy Cow! |
pete000 |
Jul 18 2017, 10:39 PM
I guess those reinforcement kits aren't just for looks after all !
brant |
Jul 18 2017, 11:09 PM
914 Wizard Group: Members Posts: 11,612 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Wow
Glad you are ok |
ChrisFoley |
Jul 19 2017, 04:51 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've never seen a failure like that on a trailing arm. Definitely a rarity.
I expected a tear where the front tube attaches to the box after talking with Matt on the phone quickly last night. My reinforcing method wouldn't prevent that from happening. I'm interested in seeing the component up close now. |
Cracker |
Jul 19 2017, 05:34 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Someone (maybe Matt) suggested a difference in the fractures - possibly showing different age. Could it have been cracked (lets say from the tie-downs) and then completing the deed on the track? Please let us know your thoughts Chris - I am very interested in your assessment!
PS: Matt: In which manner do you tie down in the rear - straps straight back or crossed? Also, do not clean the trailing arms prior to giving them to Chris... Tony |
McMark |
Jul 19 2017, 06:19 AM
(IMG:style_emoticons/default/yikes.gif) That's a scary failure. Glad it all worked out...
jd74914 |
Jul 19 2017, 06:28 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
That's crazy. Glad it didn't result in injury to you or the car. (IMG:style_emoticons/default/smile.gif)
Unrelated, but since you are a data guy have you seen the new multi-point tire temp sensors from IZZE Racing? |
bdstone914 |
Jul 19 2017, 06:36 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Have you inspected the other arm for stress cracks ?
ChrisFoley |
Jul 19 2017, 06:37 AM
Until I have a closer look I'm attributing the failure to high spring rate and curb hopping. Once a fatigue crack began at the top it didn't take long to propagate around the tube.
ChrisFoley |
Jul 19 2017, 06:42 AM
I see a change in the weld where the crack deviated. At that point the crack moved off it's HAZ path and took the shortest route toward the bottom. |
McMark |
Jul 19 2017, 06:47 AM
I see a change in the weld where the crack deviated. At that point the crack moved off it's HAZ path and took the shortest route toward the bottom. Yeah, your post made me rethink what I was seeing. Now I see the failure obviously originated from the top side. |
Matt Romanowski |
Jul 19 2017, 08:59 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
That's crazy. Glad it didn't result in injury to you or the car. (IMG:style_emoticons/default/smile.gif) Unrelated, but since you are a data guy have you seen the new multi-point tire temp sensors from IZZE Racing? I have one of the sensors, along with analog versions from Texense and AiM. For tie downs, we use the hooks on the arms straight (not crossed) to the trailer. |
Cracker |
Jul 19 2017, 09:08 AM
Chris brings up a great point in reference to the curbing. I have adopted a different approach to curbs this year...I stay off high-speed, significant (height) curbs! When the components and tubs are up to 47-years old like they are on our teeners - I felt a slightly slower lap time and different line was worth the tradeoff of protecting my car from that kind of abuse. Just sayin'...
T |
jd74914 |
Jul 19 2017, 09:57 AM
That's crazy. Glad it didn't result in injury to you or the car. (IMG:style_emoticons/default/smile.gif) Unrelated, but since you are a data guy have you seen the new multi-point tire temp sensors from IZZE Racing? I have one of the sensors, along with analog versions from Texense and AiM. For tie downs, we use the hooks on the arms straight (not crossed) to the trailer. Sorry for the hijack again but how do you like it? I've used the Texense sensor (seems to work well and Pierre is awesome) but its $$ and single point. |
gms |
Jul 19 2017, 10:35 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I've never seen a failure like that on a trailing arm. Definitely a rarity. (IMG:style_emoticons/default/agree.gif) glad you caught this before something bad happened on the track |
Matt Romanowski |
Jul 19 2017, 10:50 AM
stownsen914 |
Jul 20 2017, 05:24 AM
Senior Member Group: Members Posts: 912 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Jeez Matt, that sucks, but glad it didn't end worse for you!
And thanks for posting too. Good reminder that we need to be checking our 40+ year old cars for stuff like this. Scott |
GregAmy |
Jul 20 2017, 06:11 AM
Advanced Member Group: Members Posts: 2,267 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I'll be checking my racer as well, but I have to wonder if the welding on that bit, along with getting jacked down pretty hard there regularly, contributed to the problem. Do you cross-strap and do you jack it down pretty hard to pull down the suspension (I don't do either)?
jmitro |
Jul 20 2017, 09:16 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
wow; glad you didn't have a major accident.
PM sent |
Matt Romanowski |
Jul 20 2017, 12:25 PM
I'll be checking my racer as well, but I have to wonder if the welding on that bit, along with getting jacked down pretty hard there regularly, contributed to the problem. Do you cross-strap and do you jack it down pretty hard to pull down the suspension (I don't do either)? We put the straps straight back. We don't go crazy pulling it down, so I don't think that was it. The other side doesn't show any signs of cracks or any problems. I'm thinking this might just be a fatigued 40something year old part. I'm heading down to see Chris tomorrow and we'll see what he thinks. |
Matt Romanowski |
Jul 20 2017, 12:33 PM
Lo-Fi Version | Time is now: 25th April 2024 - 03:28 PM |
