To convert back to FI from a carb? |
Rand |
Jul 20 2017, 06:50 PM
There are several parts you can do without. CSV, AAX, yada yada. No big. I hope that's an MPS in the pic, you'll need it! I don't see injectors?
Rand |
Jul 20 2017, 06:53 PM
BeatNavy |
Jul 20 2017, 06:57 PM
There are several parts you can do without. CSV, AAX, yada yada. No big. The elephant in the room is the MPS. You need that. I don't see injectors. The injectors are there in the runners. Make sure to send them out for cleaning/servicing (Mr. Injector). I see the AAR as well. You'll also need an FI fuel pump. Just get that Bosch two port one from Tangerine. You should rush out and buy a lotto ticket tonight, too (IMG:style_emoticons/default/smile.gif) |
poorsche914 |
Jul 20 2017, 07:00 PM
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I don't see injectors? They are in the intake runners (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/driving.gif) |
bbrock |
Jul 20 2017, 07:26 PM
You'll also need an FI fuel pump. Just get that Bosch two port one from Tangerine. You should rush out and buy a lotto ticket tonight, too (IMG:style_emoticons/default/smile.gif) And what about a distributor with injector triggers? I don't see one there. |
Rand |
Jul 20 2017, 07:32 PM
I don't see injectors? They are in the intake runners (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/driving.gif) If they are there, then win! Should have been mentioned. (IMG:style_emoticons/default/smile.gif) The MPS isn't inside anything. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) Love yalls. Such a great place to sort this stuff out. |
BeatNavy |
Jul 20 2017, 07:37 PM
I don't see injectors? They are in the intake runners (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/driving.gif) The MPS isn't inside anything. (IMG:style_emoticons/default/poke.gif) It's "inside" the picture (IMG:style_emoticons/default/biggrin.gif) Don't know about dizzy. Depends on what dizzy the OP has now. |
Rand |
Jul 20 2017, 07:42 PM
Doh, I see it now. I hope this leads to a running car. So cool to see this collaboration. (IMG:style_emoticons/default/beerchug.gif)
thelogo |
Jul 20 2017, 08:01 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Unless youve built , disassembled
Troubleshooted these f.i system s many times I think its a mistake to try to assemble by piecemeal A system for these cars Lets say you test everything and it all works and you assemble And install it correctly on the car , and thats a big if . Then you fine tune it etc . Its still a 40+ old system that if any one little thing fails or partially fails its almost impossible to diagnose and will give you fits trying to figure it out . Unless see first line of this post then your ok (IMG:style_emoticons/default/chair.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 05:16 AM |
