gas gauge, works on acc.but not on run |
80cap |
Jul 21 2017, 06:53 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
My gas gauge works when you turn the key to run but when you start the engine and the key is released it goes to full scale. New sender and refurbished gauge.
80cap |
Jul 21 2017, 02:21 PM
Also a new ignition switch and wire loom in the steering column. Any advice on trouble shooting is appreciated.
jkb944t |
Jul 28 2017, 06:33 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
My gas gauge works when you turn the key to run but when you start the engine and the key is released it goes to full scale. New sender and refurbished gauge. It might be due to a faulty ground connection somewhere but that is just a guess. If the gauge is going to the full mark then it is getting full current from somewhere. Does the low fuel level light still work correctly? Jeff B |
jkb944t |
Jul 28 2017, 07:24 PM
you may want to compare the fuel sender wire connections. The picture is of a 1973 fuel sender connection so it might be a little different than the 1975 sender connections.
Jeff B |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:30 PM |
