915 transaxle with hydraulic clutch, Is a stock 914 pedal cluster throw enough to acuate a 911 clutch |
914dave |
Jul 22 2017, 09:31 AM
914 Addict Group: Members Posts: 701 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
For those off you who have a 915 with a hydraulic clutch. Did you use the stock clutch lever in the pedal cluster from a 914? The 911 pedal cluster has a different part number. Was wondering if it had a longer throw? Can't seem to get enough travel ( a little over 5/8") with a 7/8" master and slave cylinder from wilwood. Master and slave should have 1 to 1 movement ratio like a cable. Thanks in advance.
Lo-Fi Version | Time is now: 18th May 2024 - 12:31 PM |
