Paint gurus?, How to fix? |
Rob-O |
Jul 25 2017, 02:01 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Looking at this a little more, is that a trim molding at the lower edge of the red/gold stripe? If so and it runs the length of the RV and is removable that would be a great place to hide the paint line between the vertical panels that are still okay and the horizontal panel (roof) that will need to get resprayed.
As far as the stripes are concerned, it looks like tape to me. So no worries about cost of reprinting the colors. The roof would get repainted in a basecoat, then the tape applied, then cleared over. Or the tapes can be applied after the clear. If that's not trim where the red/gold line ends, is it just a body line? |
IronHillRestorations |
Jul 25 2017, 02:45 PM
Nice coach! I'd probably scrub off as much clear coat as possible with a car wash brush every time I washed it, and live with it until I was ready to paint the whole thing. The good thing is it's way up near the top and probably bothers you more than anyone. A nice coach like that with a little peeling clear coat is way better than no coach at all (IMG:style_emoticons/default/smile.gif)
UV is brutal. I have a friend who flips RV's and nearly every older low mileage unit needs front tires, simply from UV damage, and that's the bottom of the vehicle. |
Cracker |
Jul 25 2017, 08:12 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
The molding strip certainly is removable...it is covering the seam between the roof and the walls/sides. I have several options before me, albeit with no numbers or teeth applied to each as of yet. Thank you all, once again, for giving my issue time and thought! (IMG:style_emoticons/default/beerchug.gif)
T |
Lo-Fi Version | Time is now: 21st May 2024 - 08:49 PM |
