Shock tower nut tool, tool |
LowBridge |
Jul 24 2017, 06:51 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
Does anyone know where to buy the tool used to tighten and torque this nut?
injunmort |
Jul 24 2017, 06:58 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
a pipe wrench has always worked for me
LowBridge |
Jul 24 2017, 07:01 AM
914Sixer |
Jul 24 2017, 07:37 AM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bruce Stone made some up for Boges. You can contact him here. Bilstein makes one for their insert. You can find them under VW Rabbit or Golf strut nut tools. They come in two sizes though. Do not remember which one is the correct one. The larger one I think is correct.
stugray |
Jul 24 2017, 08:51 AM
a pipe wrench has always worked for me trying to use correct tools so I can torque the nut correctly... So you HAVE a "torque spec" for that nut? That is typically a "Pipe wrench and two grunts" for me. Even if you HAD the proper torque spec, how would you measure it? DO you have a 12" deep socket that can fit over the strut shaft? Or a Giant crow's foot? Some people overthink everything (I am usually one of those people :-) |
Elliot Cannon |
Jul 24 2017, 08:58 AM
I use these. (for lots of stuff) (IMG:style_emoticons/default/biggrin.gif)
McMark |
Jul 24 2017, 09:03 AM
I don't know that anyone makes a tool that will work with a torque wrench. If you really need a tool, you'll have to make it -- draw it up on the computer, do the math on how your 'crows foot' is going to change the torque setting, then have it laser cut.
Or just grab a pipe wrench or non-torque tightening tool, like pretty much everyone else. (IMG:http://www.914world.com/bbs2/uploads/post-5956-1478477937.jpg) |
Jul 24 2017, 09:21 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I use a spanner wrench from a bike shop. I use blue lock tight and make it tight.
JeffBowlsby |
Jul 24 2017, 10:35 AM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
That special wrench above can be used to torque the nut to a known value with just a spring scale if you can find something accurate, but math needs to be done. Force(lbs)*moment arm(feet) AKA Ft-Lbs, but "two grunts and pipe wrench is probably sufficient.
Porschef |
Jul 24 2017, 11:13 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Throw in an additional expletive just to be sure
PanelBilly |
Jul 24 2017, 11:24 AM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I have that same wrench but it's dirty |
LowBridge |
Jul 24 2017, 01:31 PM
found it... and it's a German car so yes it has a torque spec (IMG:style_emoticons/default/av-943.gif)
LowBridge |
Jul 24 2017, 01:32 PM
Bruce Stone made some up for Boges. You can contact him here. Bilstein makes one for their insert. You can find them under VW Rabbit or Golf strut nut tools. They come in two sizes though. Do not remember which one is the correct one. The larger one I think is correct. thank you (IMG:style_emoticons/default/beerchug.gif) |
914Sixer |
Jul 24 2017, 01:44 PM
The one Bruce made has 1/2" slot for torque wrench.
Andyrew |
Jul 24 2017, 01:50 PM
Ive used a coil over wrench before. Recently mine came loose and I tightened it up pretty easily with a pipe wrench and a rag.
rgalla9146 |
Jul 24 2017, 06:00 PM
I've tried to use those Bilstein collar tools.
If the torque required is more than 10 ft pounds you're more likely to end up in ER than finish your strut install. Attached image(s) |
Rand |
Jul 24 2017, 06:15 PM
I believe every mechanic needs to get a feel for torque. Use a torque wrench for practice and use it on everything from small to large and get a feel for it if you need to. You may twist a small bolt apart, you may not get a big one tight enough on practice tries. But once you get a real feel for it, you don't need special tools and torque wrenches for everything.
I wouldn't use slip-joint pliers as a first choice. |
Lo-Fi Version | Time is now: 5th May 2024 - 12:34 AM |
