5-point belt without cage? |
mbseto |
Jul 27 2017, 07:40 AM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
So I'm not planning to race the car I'm working on, but was thinking about the seatbelts. Would it make any sense to put 5-pt belts in it to increase safety? Would it help to make up for lack of air bags? Does it even make sense without a roll cage?
jd74914 |
Jul 27 2017, 07:42 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I don't have anything meaningful to add on the safety aspects, but if you're going to put a harness in, do yourself a favor buy a DOT one and only buy it from Schroth. (IMG:style_emoticons/default/smile.gif)
tygaboy |
Jul 27 2017, 07:51 AM
914 Guru Group: Members Posts: 5,266 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I'm assuming you've thought about this same thing:
For me it was weighing safety and convenience. In the end, I'll have both: I'm going to street drive with a 3 point retractables BUT, I'm having them made with snap hook connectors. I'm also adding installation points for the harness set up. Headed to the track? No problem! Snap, snap, click, click! All set. "Re-streeting" is 4 clicks away! |
McMark |
Racecar safety is not the same as street car safety, IMHO.
Use three point belts. |
GeorgeRud |
Jul 27 2017, 09:07 AM
Agreed!
Jul 27 2017, 09:12 AM
Yup, what McMark said!
Try belting yourself in properly with five-point belts (that means TIGHT!) and then try looking back so you can back up. Not gonna happen. Turning the radio on or off? Only if you have a remote control for it. Unlocking or opening the passenger door? Nope. Passenger window? I hope you have electric windows. Change for a toll-booth? All of those normal things you wind up doing while driving need a little bit of give, and properly fastened race belts have none. And if you're not wearing them correctly, they can be more dangerous than the three-point belts. --DD |
Jul 27 2017, 09:26 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I hate driving our customer cars with 5 point belts.
914forme |
Jul 27 2017, 09:50 AM
I plan on racing my car, and I have 3 points in for street, and a 6 point in for the track.
Used to run 5 points and things get old quick. At that point it was a race only car, that saw street duty to get to and from the event. I was to dumb to toss it up on a trailer and ride in comfort with A/C Heat, and well a radio. Plenty of good 3 points, out there, IF you go 5 points go with Schoth DOT belts. BTW DOT approved belts I think are only made in a 4 point configuration or 3 point, which requires a normal car cabin to hook up. You will also need upper mounts, and reinforcing plates, I did both front and back on my car. Under floor, and for the 6 point setup I am running 2 under the drivers seat. Also pay attention to where the harness mounts are place. Schrothh has a great writeup on this also. You will also like to stick with 2" belts for the shoulders as 3" get a bit awkward, or a 3" / 2" Hybrid belt. So after all of that, I think I would go with a 3 point with new webbing. Seat Belt Planet has some both early and later style that will work. |
914forme |
Jul 27 2017, 09:59 AM
Oh and there are lots of belt manufactures out there, I only trust my life with Schroth belts. I can go with lots of others, and lots of big names. That being said, I am willing to pay a bit extra upfront to reduce the downside. Downside in the case could be death, or disability. Neither sound like a road I want to take because I saved a few $100 dollars.
Death is in all of our cards, so thats not a choice, but it is a choice if I buy an Ebay special and test it with a sudden unplanned deceleration maneuver and knock on death's door. I'll get there soon enough with out my CSOBitist causing me to be there before it was planned. |
falcor75 |
Jul 27 2017, 11:49 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
A car without a roll cage can get unsafer from 4 or 5 point belts.
With the stock 3 point belt you can twist towards the middle of the car incase of a rollover that starts to compromise the cabin height. With a 5 point harness you are stuck upright and have no cage to help keep the cabin height intact. |
90quattrocoupe |
Jul 27 2017, 12:52 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
A car without a roll cage can get unsafer from 4 or 5 point belts. With the stock 3 point belt you can twist towards the middle of the car incase of a rollover that starts to compromise the cabin height. With a 5 point harness you are stuck upright and have no cage to help keep the cabin height intact. I am sorry, but in a rollover and centrifugal force working against you, I don't believe you could twist toward the center of the car. You might be able to do it rolling left, but definitely not right. I have rolled 3 cars and was not able to do anything during the rollover, besides hanging onto the steering wheel. Greg W/ |
Elliot Cannon |
Jul 27 2017, 06:58 PM
Inertia reel seat belts are krap! Some of the new ones will tighten up when one or more of the airbags is deployed which is a good thing. Older inertia reels will pay out a slight amount before they stop. Inertia reels were developed because people didn't like getting their clothes wrinkled. (IMG:style_emoticons/default/dry.gif) I don't like that much slack weather I'm rolling over or slamming into a power pole. (An experience I would rather avoid by the way). (IMG:style_emoticons/default/laugh.gif)
Elliot Cannon |
Jul 27 2017, 07:00 PM
A car without a roll cage can get unsafer from 4 or 5 point belts. With the stock 3 point belt you can twist towards the middle of the car incase of a rollover that starts to compromise the cabin height. With a 5 point harness you are stuck upright and have no cage to help keep the cabin height intact. You're going to lean toward the middle of the car during a rollover?? (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/poke.gif) |
Racer |
Jul 27 2017, 07:16 PM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
I would consider Shroth 4-pts. Other than that, inertia reels.
I have a '70 with OEM belts. Ugh. Like and hate em at the same time. My '76 had inertia reels for street and 5pts for the track. That was much better. As metnioned, looking back to back up, or reach across and open the passenger door or window etc is a pita with tightly worn fixed belts. |
falcor75 |
Jul 28 2017, 03:36 AM
A car without a roll cage can get unsafer from 4 or 5 point belts. With the stock 3 point belt you can twist towards the middle of the car incase of a rollover that starts to compromise the cabin height. With a 5 point harness you are stuck upright and have no cage to help keep the cabin height intact. You're going to lean toward the middle of the car during a rollover?? (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/poke.gif) I wasnt talking about during the actual rollover, I meant afterwards if the passenger compartment is compromised. If you are stuck upright with a 4 point harness and the b-billars give in, the next thing to keep the roof up is your spine. The info is from a racer in Sweden who happens to work for Volvo evaluting crash performance so I think I'll trust his opinion over anyone else on this board unless their have a similar profession. But then again, its your life and your choice, I was just trying to help. |
mbseto |
Jul 28 2017, 08:01 AM
OK, looks like 3-pt inertial belts it is. Thanks for all the information!
eeyore |
Jul 28 2017, 08:50 AM
I wasnt talking about during the actual rollover, I meant afterwards if the passenger compartment is compromised. If you are stuck upright with a 4 point harness and the b-billars give in, the next thing to keep the roof up is your spine. The info is from a racer in Sweden who happens to work for Volvo evaluting crash performance so I think I'll trust his opinion over anyone else on this board unless their have a similar profession. But then again, its your life and your choice, I was just trying to help. An off-roading fellow had this experience first hand. He rolled his pickup truck out in the desert, and he and his buddy were squished onto/into each other in the middle of the cab. He realized if he had 5 point harnesses, it would have been much worse. |
Elliot Cannon |
Jul 28 2017, 10:49 AM
This argument come up once every few years. I guess we're good for a few more years. I'm always happy to participate. (IMG:style_emoticons/default/av-943.gif)
Justinp71 |
Jul 28 2017, 11:55 AM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Have you guys noticed that the 914 inertia belts only work when you get on the brakes hard? But in a modern car they also work by pulling them very fast? Or do my 914 inertia belts need a rebuild? |
Jul 28 2017, 12:05 PM
Resident German Group: Admin Posts: 41,602 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Have you guys noticed that the 914 inertia belts only work when you get on the brakes hard? But in a modern car they also work by pulling them very fast? Or do my 914 inertia belts need a rebuild? Do you have the chrome bracket that redirects the belt so it still goes straight down from the reel? If not, your belts will never work correctly. Which is another reason why i prefer the non-retractable early style belts ... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 20th April 2024 - 04:18 AM |
