what is the best way to remove a ball joint without the tool? |
tazz9924 |
Jul 28 2017, 04:10 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
as the title states what is the best way to remove the ball joint from the control arm with out the proper tool?
mepstein |
Sep 16 2020, 06:26 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I disagree with Zach. I’ve removed the ballpoint nut on at least 20 pairs of rusty front struts. (The shop gets a lot of guys moving to 3.5” Bilsteins from 3” struts. 4 prong tool and impact gun every time.
This is the tool you want. JimmyT on pelican makes them. They are a work of art and as functional as they look. The cheap pelican tool is two piece and mine fell apart. Jimmy’s tool fits the ballpoint nut perfectly and an impact gun makes short work of the job. With the nuts costing $20 each, why use a hammer and punch which ruins the nut when you can use the right tool and reuse the hardware. Worth every penny. I do use a large pipe wrench to remove the nut that threads into the top of the strut body and holds in the insert. Hold the strut in a vice at the caliper mount and add some heat if it’s really stubborn. If you choose to use a large pipe wrench while working on your car, just be careful that you don’t pull the car off the jack stands or the lift. Seen it. It ain’t pretty. Attached thumbnail(s) |
frostyf |
Sep 16 2020, 06:35 AM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
I disagree with Zach. I’ve removed the ballpoint nut on at least 20 pairs of rusty front struts. (The shop gets a lot of guys moving to 3.5” Bilsteins from 3” struts. 4 prong tool and impact gun every time. This is the tool you want. JimmyT on pelican makes them. They are a work of art and as functional as they look. The cheap pelican tool is two piece and mine fell apart. Jimmy’s tool fits the ballpoint nut perfectly and an impact gun makes short work of the job. With the nuts costing $20 each, why use a hammer and punch which ruins the nut when you can use the right tool and reuse the hardware. Worth every penny. Thanks Zach and Mark for your advice. I bought the $70 tool from pelican. I probably need to buy an Impact wrench as I don't have one and will need it to tighten up the new nut. Is it okay to heat the base of the strut? No risk of damage to the strut end. I had an initial go with a pickle fork but the top of the old ball jt seems to be stuck in there. I don't want to damage the bottom of the strut or the control arm. Is liquid heat a spray on product? I've been soaking it with WD40 for some days! Nick |
Lo-Fi Version | Time is now: 19th April 2024 - 11:40 PM |
