16x11 & 16x10, Lindsey 3pc Never mounted |
sixnotfour |
Jul 30 2017, 08:03 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
they are hew 2 are still bubble wrapped, I have another set used these where on a 914-6.the backspacing is 6 inch $ 2500
Attached image(s) |
matthepcat |
Aug 1 2017, 11:50 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Sweet wheels.
Is it possible to find tires in 16" that are large enough and not racing slicks? Like 275 width. |
sixnotfour |
Aug 4 2017, 10:23 AM
the other set I have has slicks .. no idea on street tires
mepstein |
Aug 4 2017, 10:43 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would think the pelican guys would be all over them. Great size for an RSR or turbo.
sixnotfour |
Aug 4 2017, 11:48 AM
they are on pelican ..thanks
sixnotfour |
Sep 6 2018, 04:45 PM
$2650 shipped us
these are NLA from Lindsey new intel.,, post from seller when I bought them...dont miss this.. for fitment 2 sets of 10x16 & 11x16 Lindsey Racing 3 piece fuchs. One set new in box, the other set used at 3 events. The used set has Goodyear G19 slicks (10.5" and 11.5" R430). The 10.5 slicks still have wear left, but the 11.5 are shot. I also have another 2 10.5 G19s that can be included. The outer half on of one of the used 10s is bent and will need to be replaced (hit the wall at Lime Rock ). The backspacing is 6" both front and rear. They were on my 914/6 race car which had a 911 front suspension, so the 6" backspacing on the fronts will definitely clear a 911 strut. You may need to run a spacer to clear your calipers (I did with my 930s). Original cost was $2800 per set new (new in July of 2004) |
sixnotfour |
May 27 2019, 02:57 PM
bump
dan10101 |
May 27 2019, 05:29 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
$2650 shipped us these are NLA from Lindsey new intel.,, post from seller when I ought them...dont miss this.. 2 sets of 10x16 & 11x16 Lindsey Racing 3 piece fuchs. One set new in box, the other set used at 3 events. The used set has Goodyear G19 slicks (10.5" and 11.5" R430). The 10.5 slicks still have wear left, but the 11.5 are shot. I also have another 2 10.5 G19s that can be included. The outer half on of one of the used 10s is bent and will need to be replaced (hit the wall at Lime Rock ). The backspacing is 6" both front and rear. They were on my 914/6 race car which had a 911 front suspension, so the 6" backspacing on the fronts will definitely clear a 911 strut. You may need to run a spacer to clear your calipers (I did with my 930s). Original cost was $2800 per set new (new in July of 2004) You have my attention. But of course there are questions. Are both sets 10s and 11s? Do you know the mm offset? I'm trying to compare them to the wheels I have. Rears 11s with 2.25" spacer 45mm offset. Fronts 11s with 3" spacer 50mm offset. I'm guessing that the bent one is SOL, since they are NLA. (but the yellow has to go...) (IMG:style_emoticons/default/shades.gif) |
sixnotfour |
May 28 2019, 06:05 AM
16x10 and 16x11
10s are 12mm offset 11s are 0 offset Attached image(s) |
sixnotfour |
May 28 2019, 06:09 AM
Dans 17x11
Rears 11s with 2.25" spacer 45mm offset. Fronts 11s with 3" spacer 50mm offset. 45mm= 7.8 bs - 2.25= 5.55bs = -12mm offset 50mm= 8.0bs - 3.0= 5.00bs = -26mm offset Attached image(s) |
sixnotfour |
May 28 2019, 06:39 AM
The yellow wheel set 10 & 11 x 16 are new
2nd set is used , set is 10 & 11 x 16 are taken apart and centers repainted blue, and needing new paint and polish.... if you want 4 16x11s, buy the yellow set , i will include the correct outers to make the 10s to 11s ,,return the leftover outers back to me.. |
dan10101 |
May 28 2019, 10:16 AM
The yellow wheel set 10 & 11 x 16 are new 2nd set is used , set is 10 & 11 x 16 are taken apart and centers repainted blue, and needing new paint and polish.... if you want 4 16x11s, buy the yellow set , i will include the correct outers to make the 10s to 11s ,,return the leftover outers back to me.. Thanks for the extra effort in answering my question. I need to think about this in regards to affordable tire availability. I think 4 10s would work better for me. I certainly like the look. |
sixnotfour |
May 28 2019, 10:58 AM
The yellow wheel set 10 & 11 x 16 are new 2nd set is used , set is 10 & 11 x 16 are taken apart and centers repainted blue, and needing new paint and polish.... if you want 4 16x11s, buy the yellow set , i will include the correct outers to make the 10s to 11s ,,return the leftover outers back to me.. Thanks for the extra effort in answering my question. I need to think about this in regards to affordable tire availability. I think 4 10s would work better for me. I certainly like the look. All good , I hope it answers all the other questions .. |
sixnotfour |
Jul 17 2019, 11:40 AM
jmz |
Nov 17 2020, 01:20 PM
Member Group: Members Posts: 165 Joined: 11-April 16 From: Lone Star State Member No.: 19,886 Region Association: None |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:56 PM |
