Unused 914 On Auction Block |
porschesam |
Aug 1 2017, 04:12 PM
Newbie Group: Members Posts: 8 Joined: 10-December 04 From: Schaumburg, IL Member No.: 3,259 |
http://www.rmsothebys.com/mo17/monterey/lo...-914-18/1703704
Has anyone seen this 914 up for auction! Amazing! |
porboy |
Aug 19 2017, 12:09 AM
Newbie Group: Members Posts: 12 Joined: 23-October 09 From: El Dorado Hills Member No.: 10,967 Region Association: None |
http://www.rmsothebys.com/mo17/monterey/lo...-914-18/1703704 Has anyone seen this 914 up for auction! Amazing! Yes, went for an unbelievable 85K. |
porboy |
Aug 19 2017, 12:22 AM
http://www.rmsothebys.com/mo17/monterey/lo...-914-18/1703704 Has anyone seen this 914 up for auction! Amazing! Yes, went for an unbelievable 85K. I was 2nd owner, the orig owner was my neighbor. I sold it about 2.5 years ago. I took the AC out, the orig owner had it installed not knowing about the hack job. The hole cut in the engine compartment for the compressor let hot air in from the heat exchangers causing the motor to run too lean as well as the engine fan was blowing hot air over the motor. I had a 74' 1.8 without AC and that motor seemed to run hot as well compared to 2.0 cars I've owned. I remembered hearing about a heat problem with 1.8 heads back in the 80's. |
Cal |
Aug 19 2017, 06:22 AM
Senior Member Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
http://www.rmsothebys.com/mo17/monterey/lo...-914-18/1703704 Has anyone seen this 914 up for auction! Amazing! Yes, went for an unbelievable 85K. I was 2nd owner, the orig owner was my neighbor. I sold it about 2.5 years ago. I took the AC out, the orig owner had it installed not knowing about the hack job. The hole cut in the engine compartment for the compressor let hot air in from the heat exchangers causing the motor to run too lean as well as the engine fan was blowing hot air over the motor. I had a 74' 1.8 without AC and that motor seemed to run hot as well compared to 2.0 cars I've owned. I remembered hearing about a heat problem with 1.8 heads back in the 80's. That's interesting.....what else can you tell us about the car? Was it as nice as described in RM's write up.....was it ever repainted, oringal body panels, etc.? |
porboy |
Aug 22 2017, 11:15 PM
http://www.rmsothebys.com/mo17/monterey/lo...-914-18/1703704 Has anyone seen this 914 up for auction! Amazing! Yes, went for an unbelievable 85K. I was 2nd owner, the orig owner was my neighbor. I sold it about 2.5 years ago. I took the AC out, the orig owner had it installed not knowing about the hack job. The hole cut in the engine compartment for the compressor let hot air in from the heat exchangers causing the motor to run too lean as well as the engine fan was blowing hot air over the motor. I had a 74' 1.8 without AC and that motor seemed to run hot as well compared to 2.0 cars I've owned. I remembered hearing about a heat problem with 1.8 heads back in the 80's. That's interesting.....what else can you tell us about the car? Was it as nice as described in RM's write up.....was it ever repainted, oringal body panels, etc.? I pulled out the motor to do some work and inspected every nook and cranny of that 914, I know it better than anyone else. It was a nice $35-40K car someone bought for $85K. Why didn't the original owner drive it? I only have a suspicion, he has passed on. What about the condition you ask? I will keep these things a mystery for the new owner to ponder. Signing out and not planning to be back. |
Lo-Fi Version | Time is now: 17th May 2024 - 12:31 AM |
