My Side Windows Leak |
solex |
Aug 4 2017, 01:11 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I have tried adjusting the side windows every which way. There is absolutely no sag in the doors.
Turns out this morning we had a down pour when I need to bring my car in for an inspection. I replaced the side window rubber from (Mikey) but I'm thinking that the top rear gasket needs to be replaced. I just looked at another 914 and it seems to sit much lower. Also the point above the vent wing has a gap, does this mean the top window rubber needs to be replaced or does the front rubber on the window frame need replacement What do you think? Pictures have been attached for this morning. |
914_teener |
Aug 4 2017, 02:29 PM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
With respect to the vent wing and gaps:
There is an adjustment shoulder bolt for the frame underneath the door panels as I am sure you are aware. There are a few threads on the door adjustments. Don.t have the links jandy at the moment. |
Lo-Fi Version | Time is now: 25th May 2024 - 06:17 PM |
