anyone weld ball joint style a arms on early 911-912 a arms without hole for ball joints(whatever that is called)? I, the 911 a arms with the fat diagonal bar but no hole looks much more solid than our stock 914 a arms |
funk |
Aug 5 2017, 10:17 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
has anyone welded the a arm part with the hole onto the 911 912 early style a arms with no hole in them for a ball joint? it almost looks doable the a arms look much more of a stylish design? I know this sounds sort of wacko I just like the look of those a arms and want the fatter diagonal tube?
Mark Henry |
Aug 6 2017, 07:15 AM
McMark |
Aug 6 2017, 07:26 AM
I am just as guilty of having these sorts of ideas. But as one over-thinker to another, step away from the welder and try to worry less about the aesthetics of your a-arms.
Unless you plan on having your car upside down a lot. (IMG:style_emoticons/default/poke.gif) |
Ed_Turbo |
Aug 6 2017, 08:21 AM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Lo-Fi Version | Time is now: 18th May 2024 - 12:58 AM |
