GB -6 mufflers in stainless |
mb911 |
Oct 30 2017, 07:47 PM
914 Guru Group: Members Posts: 6,800 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mb911 |
Oct 30 2017, 07:56 PM
davehg |
Oct 31 2017, 12:23 AM
Member Group: Members Posts: 182 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
How do they sound Ben? Getting excited to see these, even if my engine build is months away from completion.
mb911 |
Oct 31 2017, 05:24 AM
mb911 |
Nov 1 2017, 09:29 AM
mb911 |
Nov 1 2017, 09:30 AM
Fixture is done and 1st one is almost done.
Steve |
Nov 1 2017, 11:09 AM
914 Guru Group: Members Posts: 5,565 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
mb911 |
Nov 2 2017, 01:51 PM
Parts are in from laser cutting and fixture is almost done.. We will start to see progress shortly.. Will have 1 ready this week to ship to someone in the group buy that will install right away to ensure fittment. I can immediately install it on my car. My car has your heat exchangers. My only concern with your car is that you run a 915 with the extension s and that may skew the results.. Not that they won't fit the same.. |
Steve |
Nov 2 2017, 03:07 PM
I agree, no problem. Can’t blame a guy for trying!! Lol
mb911 |
Nov 2 2017, 03:30 PM
Steve |
Nov 2 2017, 05:25 PM
I agree, no problem. Can’t blame a guy for trying!! Lol Its funny I test fit the muffler on Georgeruds car and it has a 915 with modded stock heatexchangers to lengthen the pipes to fit the muffler.. Was it a wevo 915 kit tail shifter? There much worse than mine. Mine is a Martin Bott 916 side shifter. Mine still requires extra clearance, but the Wevo 915 guys typically run short headers with dual mufflers. http://www.patrickmotorsports.com/project/...-speed/#image_9 or a very skinny M&K muffler. |
mb911 |
Nov 2 2017, 06:14 PM
It is the vellios kit.
Steve |
Nov 2 2017, 06:52 PM
The velios is also a side shifter, so it should be the same as mine.
mb911 |
Nov 3 2017, 05:13 AM
Yup thats what I thought.
GeorgeRud |
Nov 3 2017, 09:06 AM
The Vellios rear transmission cover requires a small spacer to clear a stock muffler (about the width of a flange is all), but the Wevo tail piece is much more intrusive. The Martin Bott system should be similar to the Vellios I would think.
Steve |
Nov 3 2017, 09:34 AM
The Vellios rear transmission cover requires a small spacer to clear a stock muffler (about the width of a flange is all), but the Wevo tail piece is much more intrusive. The Martin Bott system should be similar to the Vellios I would think. The vellios and Martin bott rear cover are both patterned off of the 916 rear cover. However I haven’t seen a reverse switch on a vellios. I have one on mine and it does stick out about an inch. |
GeorgeRud |
Nov 3 2017, 09:55 AM
No reverse switch on the Vellios. However, even without one, it does slightly interfere with a stock muffler.
live free & drive |
Nov 3 2017, 11:56 AM
Member Group: Members Posts: 154 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
Would it be possible to have added 1 1/2" to 2" to the inlet pipes for people (like me, among others) who are running a 915 trans?
Maybe for an upcharge you could provide the modification vs. having to insert/create spacers? I'm working on a 3.2 with a 915 and your HE's - I have a Vellios tail-cone, but currently have installed a stock tail-cone (with reduced features) and the PMS steel adapter frame. From my measurements the Vellios tail-cone is about 3/4" shorter than the stock tail-cone casting (measured including nothing beyond the casting surface) so I'm assuming it's going to interfere with the muffler. |
mb911 |
Nov 4 2017, 07:09 AM
Would it be possible to have added 1 1/2" to 2" to the inlet pipes for people (like me, among others) who are running a 915 trans? Maybe for an upcharge you could provide the modification vs. having to insert/create spacers? I'm working on a 3.2 with a 915 and your HE's - I have a Vellios tail-cone, but currently have installed a stock tail-cone (with reduced features) and the PMS steel adapter frame. From my measurements the Vellios tail-cone is about 3/4" shorter than the stock tail-cone casting (measured including nothing beyond the casting surface) so I'm assuming it's going to interfere with the muffler. Its possible.. The problem is that almost every order I had on the group buy wanted something special or custom and it makes very hard to break even on the project when I finish everything up.. That said its possible on this to do the upcharge as you describe. |
Steve |
Nov 4 2017, 10:32 AM
Would it be possible to have added 1 1/2" to 2" to the inlet pipes for people (like me, among others) who are running a 915 trans? Maybe for an upcharge you could provide the modification vs. having to insert/create spacers? I'm working on a 3.2 with a 915 and your HE's - I have a Vellios tail-cone, but currently have installed a stock tail-cone (with reduced features) and the PMS steel adapter frame. From my measurements the Vellios tail-cone is about 3/4" shorter than the stock tail-cone casting (measured including nothing beyond the casting surface) so I'm assuming it's going to interfere with the muffler. Its possible.. The problem is that almost every order I had on the group buy wanted something special or custom and it makes very hard to break even on the project when I finish everything up.. That said its possible on this to do the upcharge as you describe. 2” would be awesome. Maybe standardize on a 915 version and make a bunch of them. |
Lo-Fi Version | Time is now: 18th April 2024 - 11:28 PM |
