Bolster Upholstrey Install, Looking for those that have gone before me. |
Ross |
Aug 9 2017, 06:15 AM
Member Group: Members Posts: 90 Joined: 17-August 16 From: Charlotte, NC Member No.: 20,304 Region Association: South East States |
Hi Guys, do you know if there have been any postings on how to install the bolster upholstery? I checked Youtube and couldn't find any information.
Thanks for any help, Ross |
Mikey914 |
Aug 11 2017, 03:33 PM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This is what we send out when guys need a little help. There is a thread here I did but can't seem to find (We also stock these)
Pics of some plaid for inspiration http://www.914world.com/bbs2/index.php?sho...tall&st=125 914 seats are one of the most neglected parts of our cars. I’ve decided to break this process into 2 articles as I didn’t want to make a small novel on these. Part I Side bolsters and back The sides take much of the abuse that we dish out, every time you get in and out. They also show the damage as there is no texture. One of the most commonly damaged pieces of the seat are the side bolsters. To get o the Bolster you do need to disassemble much of the seat but if you are careful you will be able to re assemble without damaging the center upper section. On a scale of 1-10 this is a solid 7. It’s not that it takes any incredible skill, but it requires patience and attention to detail. Particularly when re stretching the side bolsters to get then to look right. Time required per set 3 hours for just the side and back piece. Add another hour for the back if you are going that far and another for the base, as it has a few tricks you will need to make it look correct. Tools needed 10mm socket with ratchet – set removal Med sized standard screwdriver #1 Phillips screwdriver 5mm Allen socket or socket key – base removal Small sharp knife (Exacto works well) Automotive contact cement – Camie 313 is my preference Optional – new seat adjuster handle chair to set the seat in while working To begin, remove the seat from the vehicle utilizing the 10mm socket. This is most easily done by sliding it forward and taking out all 4 10mm bolts from the back of the seat rail. The height adjustment mechanism can sometimes bind it up a little, so you may find it helpful to pull the lever arm on the side back to disengage the front section of the seat if it will not come right out. One the seat is removed you will need to take the base off . Remove the 4 allen bolts with washers and set aside for later. The seat adjuster handle need not be removed unless you are replacing yours. There is a short pictorial how to on this thread on world - http://www.914world.com/bbs2/index.php?sho...adjuster+handle If yours is missing, now if the time to replace it. Once the rails are removed, you need to start to remove the old piece. The center section will need to be removed to get access to the side sections. If you keep it intact you can easily re assemble. Attached image(s) |
Lo-Fi Version | Time is now: 7th May 2024 - 07:46 PM |
