Interior vinyl pieces |
Olympic 914 |
Aug 11 2017, 05:50 AM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Installing my interior and saved all the old pieces for patterns. But I don't know where these two pieces go. The markings on the old ones are really no help.
car did not have a console or deposit box. |
mepstein |
Aug 11 2017, 06:06 AM
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'm pretty sure it's the front of the crossmember under the seats. Just to cover the paint/transition at the end of the carpet.
sb914 |
Aug 11 2017, 06:10 AM
Surf Guru Group: Members Posts: 4,295 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
bbrock |
Aug 11 2017, 07:36 AM
rgalla9146 |
Aug 11 2017, 08:14 AM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Don't they glue to the top edge of the back wall at the outside shoulders of driver and passenger ?
mepstein |
Aug 11 2017, 08:22 AM
Tom_T |
Aug 11 2017, 10:17 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Mark has them both right.
Test fit those short pieces & they should wrap perfectly on the front of seat cross member, just between the raised areas on the side, then mark & mask the floor so you can spray that surface neatly without too much overspray clean-up afterwards (assuming you're using one of the 2 surface spray adhesives like 3M 77, 90, etc.). Do the same test fit, mark & mask for the rest too, but only spray a couple of small or 1 large piece at a time (spraying both floor area & leather backside) to give you enough out-time/dry time to get it positioned & on comfortably. Use a couple-a-3-4 long wooden dowels from Home Despot/Lowes to lay under the leatherette to prevent contact with the sprayed floor surface while you position & smooth-out & roll it on, moving them out of the way while working from one end to the other. If you've ever done Formica/etc. with 2-surfact application contact cement - it's a similar process. A small rubber roller helps with the final step of pushing the vinyl into the floor/cement, but a sturdy new/unused small paint roller can work, but requires more going back-n-forth since you can't push it as hard into the vinyl/floor. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Costa05 |
Aug 11 2017, 10:37 AM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Installing my interior and saved all the old pieces for patterns. But I don't know where these two pieces go. The markings on the old ones are really no help. car did not have a console or deposit box. I would be interested in purchasing your old pieces you saved for patterns to do the same thing you are doing. Or if someone has similar templates in electronic form they would share. |
rgalla9146 |
Aug 11 2017, 10:39 AM
Don't they glue to the top edge of the back wall at the outside shoulders of driver and passenger ? That would be the longer strips above the red circled ones. Mine actually wrap around the seam and are secured by glue and the door seal. Mark is right about the ones above the circled pieces, they mount vertically and wrap around the door pinch weld. The ones that cover the crossmember have notches for the seat recliner tooth piece. They are the upper left pieces Attached is a picture of my old rotten 1970 interior showing the last visible vestige of the rectangular piece in question. Dimensions may help. Attached image(s) |
Mikey914 |
Aug 11 2017, 10:46 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Installing my interior and saved all the old pieces for patterns. But I don't know where these two pieces go. The markings on the old ones are really no help. car did not have a console or deposit box. I would be interested in purchasing your old pieces you saved for patterns to do the same thing you are doing. Or if someone has similar templates in electronic form they would share. We actually have the patterns and sell these as a kit. Yes the smaller rectangle pieces go at the seat belt area. We are now including in our kits even though the site has not updated it. http://shop.914rubber.com/6-piece-floor-vi...m?categoryId=-1 Attached thumbnail(s) |
Mikey914 |
Aug 11 2017, 10:48 AM
These go like this
Matt may have a better picture of the seat belt area. These come up more often with the carpet replacement as most are gone or in poor condition. A detail that really finishes out the interior Attached image(s) |
mepstein |
Aug 11 2017, 10:58 AM
I was just guessing - incorrectly but now I'm sure Rory is correct.
Mikey914 |
Aug 11 2017, 11:53 AM
Matt has some pictures I'll have him post up of how it goes.
Mark |
Mikey914 |
Aug 11 2017, 04:04 PM
Also if interested I could do a GB for $24 shipped (domestic) (IMG:style_emoticons/default/biggrin.gif)
Matty900 |
Aug 11 2017, 09:57 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
They go in the area below the rear window that you can see behind the back pad.
Matty900 |
Aug 11 2017, 09:58 PM
Here's another one
Matty900 |
Aug 11 2017, 10:00 PM
A customer sent me this photo. It was the 1st time he has seen it and had done 7 cars
arne |
Aug 11 2017, 10:25 PM
Serial Rescuer of old vehicles... Group: Members Posts: 731 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Those pieces were still in my '73 when I stripped the interior. I hope my vinyl kit has them in it!
Olympic 914 |
Aug 12 2017, 06:50 AM
Lo-Fi Version | Time is now: 19th April 2024 - 02:48 PM |
