Weber Jet Sizes?, Is there a "ballpark" starting point? |
Porsche Rescue |
Jul 4 2003, 01:48 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Can someone tell me the proper jet/emulsion tube sizes for Weber 40's on a near stock 2.0 (has "carb" cam but don't know specs)? So far I have only checked the idle jets and they are 45's. The engine runs OK but I think it could be better. There is a bit of a stumble at slack throttle around 3000 rpm. I think that is about the point of transition from idle circuit to main circuit. Any suggestions out there?
maf914 |
Jul 5 2003, 09:41 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I would bet that on a street stock 2.0L 36mm vents in a 40 IDF will not provide a very strong vacuum signal at low engine speeds which will probably make low speed and transitional running kind of rough. 40 IDF's come with 28mm vents which provide good low speed response. A lot of people (including Jake and John at aircooled.net) think 28's are too small and recommend 32's for more top end.
Mike |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:41 PM |
