Toast's 914 Needs Some Help, in the Las Vegas Area |
Chris914n6 |
Aug 27 2017, 09:28 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Today's date was HOT (outside) (IMG:style_emoticons/default/lol-2.gif)
Getting the tank out required an unusual amount of effort, like the tank expanded to fill the hole (IMG:style_emoticons/default/huh.gif) But it went in easier. While waiting for my assistants to clean the tank out I tackled the little things: Replaced the randomly beeping horn ring (IMG:style_emoticons/default/biggrin.gif) Installed the door catch. Found the old broken one hiding in the door (IMG:style_emoticons/default/confused24.gif) Also lubed the latch while I was there. Toast found an extra lens in a box of dirty Lastly got the replacement pump installed just like Ron I thought she was exaggerating but right as we were cleaning up she got another drive-by offer. (IMG:style_emoticons/default/unsure.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890901.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890901.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890902.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890902.4.jpg) Next step is to replace the fuel line on the engine then it should be good to start. If we're lucky none of the FI pieces went kaput. (IMG:style_emoticons/default/piratenanner.gif) |
bdstone914 |
Aug 27 2017, 09:35 PM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Today's date was HOT (outside) (IMG:style_emoticons/default/lol-2.gif) Getting the tank out required an unusual amount of effort, like the tank expanded to fill the hole (IMG:style_emoticons/default/huh.gif) But it went in easier. While waiting for my assistants to clean the tank out I tackled the little things: Replaced the randomly beeping horn ring (IMG:style_emoticons/default/biggrin.gif) Installed the door catch. Found the old broken one hiding in the door (IMG:style_emoticons/default/confused24.gif) Also lubed the latch while I was there. Toast found an extra lens in a box of dirty Lastly got the replacement pump installed just like Ron I thought she was exaggerating but right as we were cleaning up she got another drive-by offer. (IMG:style_emoticons/default/unsure.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890901.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890901.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890902.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1503890902.4.jpg) Next step is to replace the fuel line on the engine then it should be good to start. If we're lucky none of the FI pieces went kaput. (IMG:style_emoticons/default/piratenanner.gif) Do you have a steering rack pan for it ? If not i can donate one as that pump should not be exposed like that. BTW I like the hitch pin you used in the door stay pin. I hate trying to get the cotter pins out of those. |
Toast |
Sep 15 2017, 08:17 AM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Hi guys. Just wanted to post some updates.
So I finally got her fired up for about one minute on 9/14. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/cheer.gif) Replaced all the fuel lines. Now no leaks. Here is a before pic. Notice one of the clamps is original. (IMG:style_emoticons/default/blink.gif) After cranking forever without starting I let it sit until 9/13. Then there was no ignition. (IMG:style_emoticons/default/bs.gif) So replaced the ignition switch. After fire up it ran sloppy for a minute. Pulled a spark plug.... |
Toast |
Sep 15 2017, 08:21 AM
Yeah.... So going to replace those with some cheepies then see if I can burn off all this crud out of the system then replace them again with good ones. Getting closer! (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) Thanks for following and for all of your help!! (IMG:style_emoticons/default/toast.gif) |
sb914 |
Sep 15 2017, 10:07 AM
Surf Guru Group: Members Posts: 4,295 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Yeah.... So going to replace those with some cheepies then see if I can burn off all this crud out of the system then replace them again with good ones. Getting closer! (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) Thanks for following and for all of your help!! (IMG:style_emoticons/default/toast.gif) Those plugs are toast!! (IMG:style_emoticons/default/biggrin.gif) |
Sep 15 2017, 11:23 AM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
euro911 |
Sep 15 2017, 11:38 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Keep plugging away at it. BTW, NGKs are good plugs (IMG:style_emoticons/default/shades.gif)
EDIT: ... oh, and how about an oil change? |
Toast |
Sep 15 2017, 12:17 PM
One step at a time Mark. (IMG:style_emoticons/default/rolleyes.gif)
euro911 |
Sep 15 2017, 12:31 PM
Robert21 |
Sep 15 2017, 04:52 PM
ron21 Group: Members Posts: 288 Joined: 9-July 04 From: Seal Beach Ca 90630 Orange co Member No.: 2,330 Region Association: None |
Found this from old times
boxstr |
Sep 15 2017, 09:19 PM
Those injectors look like they could stand a trip to a fuel injection rebuilder.
Craig at CAMP |
Lo-Fi Version | Time is now: 19th April 2024 - 07:19 AM |
