Ignition switches, how they fail |
porschetub |
Aug 12 2017, 04:25 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
jim_hoyland |
Aug 12 2017, 05:59 PM
Get that VIN ? Group: Members Posts: 9,256 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Is it true that a remote hot-start relay takes the pressure off the stock switch and helps prevent the failures shown above ?
Mark Henry |
Aug 12 2017, 07:15 PM
Is it true that a remote hot-start relay takes the pressure off the stock switch and helps prevent the failures shown above ? Yep, see the link in my signature. Just looking at those switches you can tell there was a fair bit of heat involved in their demise. |
porschetub |
Aug 12 2017, 08:18 PM
Is it true that a remote hot-start relay takes the pressure off the stock switch and helps prevent the failures shown above ? Yep, see the link in my signature. Just looking at those switches you can tell there was a fair bit of heat involved in their demise. Yep your starter relay fix is a good one,Mark out of 2 switches didn't really see any real heat,but mainly bad contact on the switch contact arm,funny got one from the 944 and stretched the 3 contact springs and it worked after previously being useless but its not a real fix for a sub $10 part. One reply on here was wipers that didn't work anymore,thats the first thing that happened with mine then other stuff tipped over before total failure (IMG:style_emoticons/default/sad.gif) . |
Lo-Fi Version | Time is now: 20th April 2024 - 04:34 AM |
