Ignition switches, how they fail |
porschetub |
Aug 12 2017, 04:25 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
r_towle |
Aug 12 2017, 06:06 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Thankfully, it's the same switch on mid to late 90-s vw cars.
porschetub |
Aug 12 2017, 08:46 PM
Thankfully, it's the same switch on mid to late 90-s vw cars. I mentioned same design but not same switch,mounting points are different from model to model ,depends how they fit into the back of the ignition barrel. The VW group later cars in many cases ditched this system for a more robust unit.....wonder why???. A quick look on Pelican comes up with following; meistersatz $8.25 ,have one in my car ok so far, CRP $9 ,know little of this brand?, genuine Porsche $40.50 ?. That's why I asked if anyone had used the genuine one,honest think its a crap design can't see it making too much difference (IMG:style_emoticons/default/confused24.gif) . |
Lo-Fi Version | Time is now: 26th April 2024 - 05:10 AM |
