Ignition switches, how they fail |
porschetub |
Aug 12 2017, 04:25 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
nditiz1 |
Aug 12 2017, 09:11 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Note that the genuine porsche one from PP does not include a 20% increase and 3-5 week ship from Germany. PP should really update the listing that they don't have the part and have to order it from Germany. I cancelled my order of that one for that reason.
porschetub |
Aug 12 2017, 11:52 PM
Note that the genuine porsche one from PP does not include a 20% increase and 3-5 week ship from Germany. PP should really update the listing that they don't have the part and have to order it from Germany. I cancelled my order of that one for that reason. Sorry my bad,too many people buying the $8 part lol,pretty rude how PP do that considering they are moving boxes of stuff from Porsche on a regular basis. bbrock that discussion never really came to a final outcome on the genuine switch,some having issues with the cheap ones however. |
Lo-Fi Version | Time is now: 23rd April 2024 - 12:28 AM |
