Ignition switches, how they fail |
porschetub |
Aug 12 2017, 04:25 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
McMark |
Aug 13 2017, 08:24 AM
As 3D printing has evolved I've wondered if someone would pick up this project and do it right, once and for all. It's a complicated little part, but I would be happy to pay a premium for a part that I knew was designed and built well and addresses these issues.
Seems like the biggest issue could be just the material choice. Perhaps that type of plastic isn't up to the job... (IMG:style_emoticons/default/idea.gif) |
Mark Henry |
Aug 13 2017, 11:30 AM
As 3D printing has evolved I've wondered if someone would pick up this project and do it right, once and for all. It's a complicated little part, but I would be happy to pay a premium for a part that I knew was designed and built well and addresses these issues. Seems like the biggest issue could be just the material choice. Perhaps that type of plastic isn't up to the job... (IMG:style_emoticons/default/idea.gif) I have a switch off of a VW and it has a metal case. I know it's off of an air cooled, I think T3. I'd have to dig it out of my stash, very similar, but I know it wouldn't work on a 914 as it has wire leads. Just mentioning this as a metal case could be made to work. |
Lo-Fi Version | Time is now: 18th April 2024 - 05:53 PM |
