Ignition switches, how they fail |
porschetub |
Aug 12 2017, 04:25 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
nditiz1 |
Aug 13 2017, 06:16 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I did call the local dealership, but the guy on the other end seemed below par for working in parts as he asked me for my whole vin number after I gave him the digits for my 73. I didn't have the part number and not sure he quoted me correctly but said somewhere around $170.
mepstein |
Aug 13 2017, 06:23 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I did call the local dealership, but the guy on the other end seemed below par for working in parts as he asked me for my whole vin number after I gave him the digits for my 73. I didn't have the part number and not sure he quoted me correctly but said somewhere around $170. I use our local one pretty frequently for small parts. I also get a shop discount. If you figure out the correct part number, let me know and I'll get you a price. I'll only charge you what they charge me. I drive past on my way to work so I stop in often. |
Lo-Fi Version | Time is now: 19th April 2024 - 10:16 PM |
