Ignition switches, how they fail |
porschetub |
Aug 12 2017, 04:25 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Had one fail in my 914,there seems to be a common failure point around the top casing that fits to the main assembly,this design is the the same for early Golf,944,T 1 and T2 aircooled Audi and I would expect many other in "the family''.
The return spring mounts via a tab on the spring into a hole in the top assembly,repeated use causes the area to crack. The result is that the green plastic centre section loses tension and pops upward which in turn causes the metal wiper plate inside the switch to make a poor contact as it moves through its arc. The end result of this poor contact is complete or partial failure,the crack in the housing shown in picture 2 is from my early 944 switch this was enough to stop injector pulse due to insuffient power to my ECU. I pulled a known bad switch from another VW I had and found no crack in the housing but the contacts inside were all gummed up as the grease had gone bad and the contact pins were oxidized,cleaned it and it worked in the 944 till the correct replacement arrived. |
nditiz1 |
Aug 14 2017, 06:02 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Does anyone know if the part number above will work in a 73? I thought the last character "L" had to be a "K" or something else (another thread talked about it I think)
michael7810 |
Aug 14 2017, 07:16 AM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Does anyone know if the part number above will work in a 73? I thought the last character "L" had to be a "K" or something else (another thread talked about it I think) According to Pelican site the K is for 70-74 and the L is for 75-76. I bought the Meistersatz brand from Pelican in April and it's already starting to fail. I too was surprised by Pelican after ordering a genuine Porsche to get an email stating it would be a 20% increase and 5-6 weeks. I cancelled the order because I needed the switch for WCR and bought the Meistersatz, but now I'm In the same boat getting ready for RRC. I'll rig up a bypass wire until I can install an OEM switch. I wish Pelican would stock the damn switches. Seems like there is enough demand to justify. |
Lo-Fi Version | Time is now: 25th April 2024 - 02:08 AM |
