AC on the cheap |
AC on the cheap |
bandjoey |
Aug 12 2017, 10:53 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
If you haven't been watching Zero Breeze then google it. Small portable scroll compressor AC unit that looked promising. However after raising over $1MILLLLIOOONNN it looks like it's just another scam. See the comments on their www.
So the transmission goes out on the Explorer Friday and can't be fixed until Monday, and I have to work. On the road sales. 98 degrees + humidity and my backup car is the teener. Take a 28qt ice chest, blend it gently with hole saws, epoxy in a pipe and a fan. Add a bag of ice and everything in the freezer and away we go. This really worked for an hour keeping me cool enough but not super cold. Then the ice melted. Verdict? I'll be using it again tomorrow. Just know it's ah hour between ice stations. Attached thumbnail(s) |
90quattrocoupe |
Aug 13 2017, 03:41 AM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
How about dry ice?
Greg W. |
maf914 |
Aug 13 2017, 05:52 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
How about dry ice? You might want to monitor the CO2 level in the cockpit if you try this. (IMG:style_emoticons/default/idea.gif) |
michael7810 |
Aug 13 2017, 06:43 AM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
BTDT. If you want to go to the next level in "cheap" AC, add a heat exchanger and water pump similar to the B-Kool (b-kool.net). I ended up buying a B-kool and have no regrets because it keeps me cool in the desert heat but you can copy the design for half of what I paid. I didn't get good results with just air blowing over the ice...but then again I live in the desert where it hits 120F.
McMark |
Aug 13 2017, 08:01 AM
Use a 914 heater aux fan for MUCH more airflow. That style of fan, in that orientation is pretty inefficient. (IMG:style_emoticons/default/wink.gif) Also, if you didn't already, extend the blower pipe to near the bottom of the cooler to get the air to spend more time in contact with the ice.
MartyYeoman |
Aug 13 2017, 08:38 AM
Senior Member Group: Members Posts: 1,516 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Looks like something Ellyut would invent. (IMG:style_emoticons/default/sawzall-smiley.gif)
Elliot Cannon |
Aug 13 2017, 11:16 AM
Mine had an enclosed water system that circulated water through a coil of copper tubing that was immersed in a cooler of ice water to a heat exchanger with a blower motor circulating the cold air. It was not an evaporative system and worked great for a few hours. I have a two hour bladder anyway, so a stop for a men's room and more ice wasn't a problem. (IMG:style_emoticons/default/biggrin.gif) Unfortunately it turned into one of those projects that got put on the back burner that might be re-visited someday soon. In the future sometime. Maybe. (IMG:style_emoticons/default/laugh.gif) I don't drive the 914 everyday and when it gets really hot I drive my F-150 that has great air conditioning. Cheers, Elliot |
PlaysWithCars |
Aug 13 2017, 05:59 PM
Senior Member Group: Members Posts: 521 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Use a 914 heater aux fan for MUCH more airflow. That style of fan, in that orientation is pretty inefficient. (IMG:style_emoticons/default/agree.gif) Would create a lot more airflow and be more correct for the car. (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 18th April 2024 - 11:56 PM |
