Console Install |
Console Install |
TheCabinetmaker |
Jul 5 2003, 03:00 PM
There are two holes on the bottom of the "U", and one hole on each side at the end with a nut tack welded in place. The bracket measures 5 1/2" wide and the ends are 3 1/2". I think it would be simple to make one. Its just a piece of light gage steel with two bends and four holes and two nuts.
Curt (IMG:style_emoticons/default/happy11.gif) |
rhodyguy |
Jul 5 2003, 07:39 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
13 1/2 on the tall, 11 1/2 on the short. neal for heavens sake go to sir tomorrow if you can.
kevin |
Neal |
Jul 5 2003, 08:06 PM
Member Group: Members Posts: 300 Joined: 23-April 03 From: Sammamish, Washington Member No.: 605 |
Son's 17th B/D today tommrow is free, whats up at SIR ?
anthony |
Jul 5 2003, 08:41 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Just make the top bracket. Like vsg said it should be pretty easy to do with some tin snips and sheet metal from the hardware store. Really you don't even need the top bracket. I have the A/C console without the A/C unit installed and it's bolted down securely enough just from the bottom.
Lo-Fi Version | Time is now: 25th April 2024 - 10:22 PM |
