Transmission Serial Number |
kgruen2 |
Aug 17 2017, 11:22 AM
Member Group: Members Posts: 109 Joined: 22-February 15 From: Prescott, Az. Member No.: 18,459 Region Association: Southwest Region |
Looked for transmission serial number for COA. Found what looks like a part number, 914.301.101.00. Is this the serial number? If not, where located? ' 73 2.0 side shifter.
(IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
Aug 17 2017, 11:31 AM
Bottom rib on the case.
Mark Henry |
Aug 17 2017, 11:33 AM
Right on the bottom of the rib, it will look something like below. Sometimes if the trans has been dragged across the floor many times it's wore off, more often it's totally covered in grease/grime.
(IMG:http://www.914world.com/bbs2/uploads/post-3578-1286924232.jpg) |
Cairo94507 |
Aug 17 2017, 01:31 PM
Michael Group: Members Posts: 9,719 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Wow Mark - That one looks pristine. Most I have seen look terrible. Good luck OP.
kgruen2 |
Aug 17 2017, 02:19 PM
Right on the bottom of the rib, it will look something like below. Sometimes if the trans has been dragged across the floor many times it's wore off, more often it's totally covered in grease/grime. (IMG:http://www.914world.com/bbs2/uploads/post-3578-1286924232.jpg) Found it, right where you said it would be. Thanks Mark. Here's a pic, looks a little different from yours. Look right to you? HA 06 03 3. |
bbrock |
Aug 17 2017, 02:33 PM
I was literally getting ready to walk out to the shed to pull the number on the trans for exactly the same purpose. Decided to get a quick update on the World first. Glad I did! Thanks!
Dave_Darling |
Aug 17 2017, 02:45 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
kgruen2 |
Aug 17 2017, 02:46 PM
I was literally getting ready to walk out to the shed to pull the number on the trans for exactly the same purpose. Decided to get a quick update on the World first. Glad I did! Thanks! You're welcome. Whenever someone has a question or needs info, there are probably many others that do too. |
rgalla9146 |
Aug 17 2017, 03:32 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Right on the bottom of the rib, it will look something like below. Sometimes if the trans has been dragged across the floor many times it's wore off, more often it's totally covered in grease/grime. (IMG:http://www.914world.com/bbs2/uploads/post-3578-1286924232.jpg) Hey Mark if you have any other boxes with marking 'something like below' I'd be interested. But only the ones that have 'HB', wink wink. |
Mark Henry |
Aug 17 2017, 04:23 PM
Right on the bottom of the rib, it will look something like below. Sometimes if the trans has been dragged across the floor many times it's wore off, more often it's totally covered in grease/grime. (IMG:http://www.914world.com/bbs2/uploads/post-3578-1286924232.jpg) Hey Mark if you have any other boxes with marking 'something like below' I'd be interested. But only the ones that have 'HB', wink wink. Wow Mark - That one looks pristine. Most I have seen look terrible. Good luck OP. Not mine...google is my friend. (IMG:style_emoticons/default/wink.gif) |
sixnotfour |
Aug 17 2017, 06:29 PM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
HB 2und
kgruen2 |
Aug 18 2017, 02:13 AM
I was literally getting ready to walk out to the shed to pull the number on the trans for exactly the same purpose. Decided to get a quick update on the World first. Glad I did! Thanks! Hey. I used be be able to lift weights like that. (IMG:style_emoticons/default/biggrin.gif) |
kgruen2 |
Aug 18 2017, 02:17 AM
dlkawashima |
Aug 18 2017, 12:16 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
As I recall that serial number also is the date of manufacture in a day/month/year configuration with only the last digit of the year being represented ... March 6, 1973 in your CASE.
bbrock |
Aug 18 2017, 12:23 PM
I was literally getting ready to walk out to the shed to pull the number on the trans for exactly the same purpose. Decided to get a quick update on the World first. Glad I did! Thanks! Hey. I used be be able to lift weights like that. (IMG:style_emoticons/default/biggrin.gif) Ha! I suppose I should explain that the transmission has been off the car and moved from storage shed to storage shed for decades. Even then, it gets heavier every time I lift it. (IMG:style_emoticons/default/biggrin.gif) Hopefully, I'll get it reunited with the engine and car in the not too distant future. (IMG:style_emoticons/default/beerchug.gif) Oh wait, or are you talking about my dumbells. Those are helium balloons! |
jrmdir |
Jun 29 2021, 07:10 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Right on the bottom of the rib, it will look something like below. Sometimes if the trans has been dragged across the floor many times it's wore off, more often it's totally covered in grease/grime. (IMG:http://www.914world.com/bbs2/uploads/post-3578-1286924232.jpg) This is very helpful and timely! Thanks, Ron |
Lo-Fi Version | Time is now: 29th April 2024 - 12:48 PM |
