Brake question, Soft pedal |
Mike's2nd914 |
Jul 4 2003, 04:52 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
Hey guys, I could use a little help. I just got finished bleeding down the brake system after rebuilding all four calipers. The brakes worked when I started this project but I had one (or more) calipers that were frozen. Now, the calipers all work great and I believe I have bled all the air out of the system but there is still way too much travel in the pedal and I have to pump the pedal a couple of times to get any brakeing. What's up? It took about a month and a half to get everything rebuilt during which time the car sat up with little or no fluid in the brake system. Could the master cylinder, that was working fine before this, could it have gone bad just sitting there? (IMG:style_emoticons/default/headbang.gif)
I appreciate any help or suggestions! |
Porsche Rescue |
Jul 4 2003, 05:49 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
If you have to pump to get any firmness in the pedal you have air in there. I would bleed again. Also I have had major improvement by bleeding the proportioning valve (on the firewall under and in front of the engine). Crack the fitting of the outlet line (wrap a rag around it to catch the fluid) while the system is under pressure just as if you were bleeding a caliper.
Lo-Fi Version | Time is now: 20th May 2024 - 08:21 PM |
