Brake question, Soft pedal |
Mike's2nd914 |
Jul 4 2003, 04:52 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
Hey guys, I could use a little help. I just got finished bleeding down the brake system after rebuilding all four calipers. The brakes worked when I started this project but I had one (or more) calipers that were frozen. Now, the calipers all work great and I believe I have bled all the air out of the system but there is still way too much travel in the pedal and I have to pump the pedal a couple of times to get any brakeing. What's up? It took about a month and a half to get everything rebuilt during which time the car sat up with little or no fluid in the brake system. Could the master cylinder, that was working fine before this, could it have gone bad just sitting there? (IMG:style_emoticons/default/headbang.gif)
I appreciate any help or suggestions! |
tat2dphreak |
Jul 4 2003, 06:54 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
definately sounds like air in the lines to me... I had a heck of a time bleeding mine... the prop. valve is the key, or at least it was to mine... treat it like a 5th caliper! also... as good as mityvac type tools are... they aren't as good at finishing the job as the 2-person method IMHO. get it bled as good as possible, then draft a friend, (IMG:style_emoticons/default/chatsmiley.gif) or one of your kids to pump the brakes for you.
good luck! (IMG:style_emoticons/default/dance.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:19 PM |
