Brake question, Soft pedal |
Mike's2nd914 |
Jul 4 2003, 04:52 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
Hey guys, I could use a little help. I just got finished bleeding down the brake system after rebuilding all four calipers. The brakes worked when I started this project but I had one (or more) calipers that were frozen. Now, the calipers all work great and I believe I have bled all the air out of the system but there is still way too much travel in the pedal and I have to pump the pedal a couple of times to get any brakeing. What's up? It took about a month and a half to get everything rebuilt during which time the car sat up with little or no fluid in the brake system. Could the master cylinder, that was working fine before this, could it have gone bad just sitting there? (IMG:style_emoticons/default/headbang.gif)
I appreciate any help or suggestions! |
Lawrence |
Jul 5 2003, 08:31 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Speed bleeders are awesome.
I would recommend rebleeding. This time only put the rear of the car up in the air.. then lower it and do the front. Keeping just one end of the car up, will help coax the bubbles up through the lines to the calipers. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:19 PM |
