wiring up the engine |
JFG |
Aug 17 2017, 02:54 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
My car came minus most things in the engine area, including the engine & tranny. I have no point of reference to work back from.
Tonight i made a new alternator harness and wired that in. I think the starter motor wire from the battery is routed over the tranny so i've just looped that over for testing. I have a new 34 svda distributor to fit which has a black wire and a red wire (electric module not points). I also extended the existing fuel pump wires in order to run the new pump up front under the tank from the existing ignition / relay design. Now all i have is one green wire which i believe is for the head temp sensor. There are no other wires in the engine bay. So what wires are missing to successfully wire up and run the engine? The starter has only the battery cable & alternator cable fitted to number 30? Connector, the spades are empty. The coil has nothing connected to it. The relay board has the main loom connected and all relays are present. It'a 74 2.0 running twin 40idf's. I cannot read electrical diagrams such as what ypu find in haynes manuals etc. |
JFG |
Aug 17 2017, 11:56 PM
Where would the +12v come from for the coil? I'm assuming not direct from the battery!
I've already been through the loom and there are no wires free that would have gone to the oil pressure switch. I can run a wire from neg to the rev counter (just about). What colour should oil pressure switch be, green? As it's not there what would be the way to add a fresh wire to complete the circuit? |
Lo-Fi Version | Time is now: 17th May 2024 - 12:30 AM |
