question for the brain trust, relocating fuel pump to front |
hndyhrr |
Aug 17 2017, 07:13 PM
Senior Member Group: Members Posts: 553 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
The pumpkin is a 70 1.7 with fi.
Took the pan off that covers the rack and pinion up. There is not enough room under there to mount the fuel pump and put the cover back on. Is the 70 body some how different up front? Are there different pan's that cover the rack? Am stuck don't really want to put it in the front trunk and don't want to cut a door like where porsche changed it to. oh hell think i'll go have a beer and think on it some more. thanks for any ideas Renee |
Olympic 914 |
Aug 17 2017, 07:24 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
When I first moved the fuel pump to the front, I put it under the cover and had to adjust the cover with a hammer.
Didn't like it there and this time I put it under the tank. its even easier if you don't have a sway bar in the way. |
mgphoto |
Aug 17 2017, 07:26 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
It fits very very tight, pan may even bend a little.
You could convert to the later fuel pump, which has only one in and one out, slimmer body mounted in the same position simpler plumbing. |
914_teener |
Aug 17 2017, 08:35 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I put mine on the rear firewall under the engine compartment on the passenger side.
There are threads on this. Way easier than the front. Been 8 years no issues and in temps way over 100 degrees. |
Tom_T |
Aug 17 2017, 08:46 PM
I think that you might be trying to place it in the wrong spot slightly, cuz this was the factory's Service Bulletin fix for the FP relocation to resolve the vapor lock problem on all 70-74 914s, & I don't think that they changed the steering rack cover/pan nor the body pan in the 70-74 MYs AFAIK.
It's placement should be over near center toward the passenger side of the 3-4" outlet hole where the fuel lines come out. It should make no difference to switch to a later 2-port pump space-wise, but it will complicate your replumbing to a 2-line system. Also, the thing about putting the FP up inside under the tank as in the pic above, that I'm sure the factory also considered, is that you then would have to pull out the tank & all the plumbing & other stuff in the way, just to replace the pump or any lines which may leak. Putting it there can easily 2-3x the labor time or cost to do that otherwise simple operation. Unfortunately I don't have a copy of that factory Service Bulletin to show you, but here are some pix of mine done in the late 70's by my factory trained 914 mechanic (not pretty at this point). I'm not sure if he had to tweak my 73 2L's steering rack cover/pan, but I think not since it looks the same as the NOS one I have to replace the original in my resto. Hopefully it will give you a better idea how to place yours. These weren't taken to show the install per se, but to document my tinworm assessment issues, but hopefully they'll help you placing it. The 2nd pic shows the "box" OE fuel filter up inside the portal FYI. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Spoke |
Aug 17 2017, 09:06 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I relocated the pump to under the tank by the driver footwell. The hardest part was fishing an extension cord-type 2 conductor wire through the tunnel.
While under the fuel tank, if hoses are made long enough, the tank can be removed without disconnecting the hoses. I don't like the pump under the front steering rack as it's quite a dirty place as is the original location in the engine compartment. |
porschetub |
Aug 17 2017, 11:54 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Fitted a carter pump there no issues but think the stock FI pump being larger could be an issue,the replacement 2 port ones are smaller in diameter from my research,I personally like this fitment because it gives a contant "head" of fuel to the pump and it runs easier through the shorter fuel line which is better for the pump in the long term.
jim912928 |
Aug 18 2017, 08:55 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
late models had the fuel pump under the gas tank with an access panel from the trunk side (fuel pump is actually attached to the access panel).
Here is where mine is at (stock location for a 75)...note: it's a 911 fuel pump as I'm feeding a 3.2l...but the location is stock. |
JawjaPorsche |
Aug 18 2017, 03:02 PM
I put mine on the rear firewall under the engine compartment on the passenger side. There are threads on this. Way easier than the front. Been 8 years no issues and in temps way over 100 degrees. I agree. I moved mine there over 20 years ago with no issues. Much easier to change fuel filter too. |
EdwardBlume |
Aug 19 2017, 05:40 AM
I used the AA kit about 20 years ago in my old gray AX car. It mounted next to the spare tire on the passenger side with holes into the fender well. It worked OK, and since it was an AX car, I was in there changing tires, etc at all events. I liked how easy it was to get to and install, but hated that fact that it was THERE.
For Dad's car, I moved it to the rear firewall after seeing all of the nice installs. I really like it there and so far so good. I also changed it from a 3 port to a 2 port. |
hndyhrr |
Aug 19 2017, 01:27 PM
When I first moved the fuel pump to the front, I put it under the cover and had to adjust the cover with a hammer. Didn't like it there and this time I put it under the tank. its even easier if you don't have a sway bar in the way. prudy color and soooooo clean |
hndyhrr |
Aug 19 2017, 01:30 PM
Thanks guys for your replies, pic's help alot.
In cleaning my fuel pump up notice that it has yellow junk yard makings on it so I am thinking to replace it, not that it doesn't work good it does but...... so next question is what brand should i buy and is the pump something i could get local? thanks again Renee |
Olympic 914 |
Aug 19 2017, 02:26 PM
I used a bosch 044 pump. two port and has plenty of pressure for FI
Lo-Fi Version | Time is now: 20th April 2024 - 03:33 AM |
