> Taco Plate Gasket, paper or rubber ?
Olympic 914
post Aug 18 2017, 07:52 AM
will be installing a taco plate with temp sender on my next oil change.
I see the PET lists two gaskets for this application.
021 101 269A is a rubber o-ring for non sender plate
039 101 287 is a paper gasket. for the sender plate.
little copper seals are the same for both.
I remember using the rubber o-ring when installing the non-sender taco plate.
why is there a different gasket for the sender version?
Are they interchangeable?
era vulgaris
post Aug 18 2017, 08:44 AM
J is for Genius
You'll need both. It's been over a year since I did this on my old car, but IIRC there's one seal that's for the plate that holds the sender, and then one for the cover plate. I can't remember which is which, but it'll be obvious when you're putting them on.
Valy
post Aug 18 2017, 09:12 AM
You need both and the copper washers.
The paper gasket must be replaced, the others can be reused several times.
See my signature for the paper gasket templates.
- Lo-Fi Version Time is now: 9th September 2026 - 06:57 PM
