Porscharu Cooling, scott? |
lapuwali |
May 18 2005, 01:16 PM
So, Mssr. Thatcher, since you've proved the effectiveness of your cooling system setup, could you post detailed photos and/or diagrams of your radiator and ducting arrangement? Pretty please? With sugar on top?
scotty914 |
May 18 2005, 04:45 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
okay but only because you asked nicely
the first pic here is the frame i built welded to the fire wall ( its a repeat ) basicly it is a 1 inch angle welded in a rectangle the same size as the radiator with a tab welded to it with a hole for a rubber grommet for the pin mount in the bottom of the radiator. the sides of the angle are set up so the can have the shroud screwed to it. then there is a 1/2 by 1/2 inch angle piece that is welded to the radiator frame and the floor board of the car to support the scoop more diagrams in a few mins Attached image(s) |
scotty914 |
May 18 2005, 05:45 PM
opps camera batterys are dead
i will draw up some diagrams and post them tommarrow |
Lo-Fi Version | Time is now: 28th May 2024 - 07:34 PM |
