electrical woes |
electrical woes |
Mike1981 |
Aug 19 2017, 12:03 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello everyone
Hoping to get some electrical help on my 72 It has a V8 in it but will not pass any power No buzzing of the fuelpump No dash lights No radio no horn nothing I pulled the ignition switch and tested it It was open until I turned the key and ohmed to almost 0 ohms When I released it open circuit Checked all wires in harness good Ohmed out every fuse in the panel below dash as well as a few in the rear of the car. Checked the ground strap (now a battery Cable) At first I was not getting continuity between the tranny bolt and the body Cleaned up the connection to the tranny as well as to the body ohms out to 2 ohms Checked the battery 12.5 volts Ohmed from neg terminal to chassis ground ohmed to 2-3 ohms It was running fine yesterday until i turned on the headlights while staring it then it died and I havent been able to get it to crank Any help would be appreciated thanks MIke |
Spoke |
Aug 19 2017, 12:22 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Do the lights come on with ignition off?
Do you have any electrical power on anything? How about the 4-way flashers? They work with or without key in. Did you clean the battery terminals? How about the ground strap from battery negative to ground? Is it tight? What is the battery voltage from positive terminal to chassis ground (not batt neg)? |
Mike1981 |
Aug 19 2017, 02:17 PM
Do the lights come on with ignition off? Do you have any electrical power on anything? How about the 4-way flashers? They work with or without key in. Did you clean the battery terminals? How about the ground strap from battery negative to ground? Is it tight? What is the battery voltage from positive terminal to chassis ground (not batt neg)? No lights at all No power at all 4-way flashers do not work re-cleaned battery terminals tight battery neg to chassis ground 12.3 volts re tightened ground strap to chassis and tranny no power on fusebox under dash 3 vdc when key is off 0vdc when key is on thanks for your help |
Spoke |
Aug 19 2017, 02:27 PM
battery neg to chassis ground 12.3 volts You mean battery POS to ground? If battery NEG to chassis ground then there is no connection between battery NEG and chassis. What condition is the negative cable between battery and the chassis bolt above the battery? If nothing works, then it's likely the battery or wiring, not your ignition switch or the engine ground strap. Try this test: Turn lights or 4-ways on. Measure voltage across the TERMINALS of the battery, not the clamps. Touch the battery terminals. Then measure voltage from POS terminal to POS battery clamp. Then measure voltage from NEG terminal to NEG battery clamp. Here we're trying to find where the battery voltage starts and where it ends since it's not making it to any components. |
Mike1981 |
Aug 19 2017, 02:58 PM
battery neg to chassis ground 12.3 volts You mean battery POS to ground? If battery NEG to chassis ground then there is no connection between battery NEG and chassis. What condition is the negative cable between battery and the chassis bolt above the battery? If nothing works, then it's likely the battery or wiring, not your ignition switch or the engine ground strap. Try this test: Turn lights or 4-ways on. Measure voltage across the TERMINALS of the battery, not the clamps. Touch the battery terminals. Then measure voltage from POS terminal to POS battery clamp. Then measure voltage from NEG terminal to NEG battery clamp. Here we're trying to find where the battery voltage starts and where it ends since it's not making it to any components. Yes you are correct Positive teminal to chassis is 12.3 volts I turned on 4-ways No lights as before 0 volts bet pos terminal to pos clamp 0 volts from neg terminal to neg clamp |
Spoke |
Aug 19 2017, 03:16 PM
OK, sounds like the battery terminals are tight.
No voltage at the fuse panel? The first 3 fuses from the center of the car outward are constant 12V. If not 12V, then some wiring issue is at play. How do the small wires look coming off the POS terminal? These wires go to the fuse panel. Before you go behind the fuse panel, disconnect the battery NEG terminal. Do NOT move the fuse panel with battery connected. Behind the fuse panel is a POS terminal block on the side of the chassis. Make sure this is tight. With the fuse panel down, make sure no connections touch anything. Connect NEG terminal to battery. Test the positive terminal block behind the fuse panel from terminal block to chassis. Should be 12V. |
76-914 |
Aug 19 2017, 03:24 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Do you still have the OEM positive clamp w/ 3-4 ~10ga wires and a large 2ga cable to starter. IIRC, one of those wires goes to the fuse panel and the other to the ignition switch. Find that wire and check it. If you do have 12v then put some load on it and see if you lose the 12v. I've had some bad connections give me a good reading until they get a little load on them. (IMG:style_emoticons/default/beerchug.gif)
Mike1981 |
Aug 19 2017, 03:35 PM
OK, sounds like the battery terminals are tight. No voltage at the fuse panel? The first 3 fuses from the center of the car outward are constant 12V. If not 12V, then some wiring issue is at play. How do the small wires look coming off the POS terminal? These wires go to the fuse panel. Before you go behind the fuse panel, disconnect the battery NEG terminal. Do NOT move the fuse panel with battery connected. Behind the fuse panel is a POS terminal block on the side of the chassis. Make sure this is tight. With the fuse panel down, make sure no connections touch anything. Connect NEG terminal to battery. Test the positive terminal block behind the fuse panel from terminal block to chassis. Should be 12V. Thanks I will re-check the smaller wires coming off the POS terminal at the battery. I will then disconnect the NEG terminal and drop the fuse panel and make the check you recommend thanks for your help. Mike |
Mike1981 |
Aug 19 2017, 03:36 PM
Do you still have the OEM positive clamp w/ 3-4 ~10ga wires and a large 2ga cable to starter. IIRC, one of those wires goes to the fuse panel and the other to the ignition switch. Find that wire and check it. If you do have 12v then put some load on it and see if you lose the 12v. I've had some bad connections give me a good reading until they get a little load on them. (IMG:style_emoticons/default/beerchug.gif) I have some really heavy gauge wires going back to the starter I put my pos terminal from my multi meter onto the pos on the starter and sparks flew. I will send a pic of what I have thanks Mike |
Mike Bellis |
Aug 19 2017, 04:29 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Sounds like 2 of the 4 wires connected to the positive battery terminal are disconnected. 2 go to the alternator circuit and 2 go to the fuse panel/ignition switch.
Mike1981 |
Aug 19 2017, 07:18 PM
Sounds like 2 of the 4 wires connected to the positive battery terminal are disconnected. 2 go to the alternator circuit and 2 go to the fuse panel/ignition switch. I think you may be onto something i will trace 4 wires back and make sure the connections are tight |
whitetwinturbo |
Aug 21 2017, 09:18 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Mike1981 |
Aug 22 2017, 01:15 PM
Hello Everyone
Thanks for all the help. I pulled the NEG off the battery and dropped the fuse panel Behind it was a terminal block with the positive lead attached just as I was told. I only measured 3.2 VDC when the key was off and 0 when it was on. Puzzled I once again checked the fuses this time in the back of the car. I found 1 fuse that was a 30 amp. It tested good but was melted. I had to pull it out with pliers and thus destroyed it. Went to the auto parts store and picked up a new fuse. Took some emery paper to the contacts. Plugged her in and what do you know I have power and she is running again! You are the most helpful group of folks I know. Thanks very much! Mike |
Lo-Fi Version | Time is now: 5th May 2024 - 06:11 PM |
