electrical woes |
electrical woes |
Mike1981 |
Aug 19 2017, 12:03 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello everyone
Hoping to get some electrical help on my 72 It has a V8 in it but will not pass any power No buzzing of the fuelpump No dash lights No radio no horn nothing I pulled the ignition switch and tested it It was open until I turned the key and ohmed to almost 0 ohms When I released it open circuit Checked all wires in harness good Ohmed out every fuse in the panel below dash as well as a few in the rear of the car. Checked the ground strap (now a battery Cable) At first I was not getting continuity between the tranny bolt and the body Cleaned up the connection to the tranny as well as to the body ohms out to 2 ohms Checked the battery 12.5 volts Ohmed from neg terminal to chassis ground ohmed to 2-3 ohms It was running fine yesterday until i turned on the headlights while staring it then it died and I havent been able to get it to crank Any help would be appreciated thanks MIke |
Spoke |
Aug 19 2017, 12:22 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Do the lights come on with ignition off?
Do you have any electrical power on anything? How about the 4-way flashers? They work with or without key in. Did you clean the battery terminals? How about the ground strap from battery negative to ground? Is it tight? What is the battery voltage from positive terminal to chassis ground (not batt neg)? |
Mike1981 |
Aug 19 2017, 02:17 PM
Do the lights come on with ignition off? Do you have any electrical power on anything? How about the 4-way flashers? They work with or without key in. Did you clean the battery terminals? How about the ground strap from battery negative to ground? Is it tight? What is the battery voltage from positive terminal to chassis ground (not batt neg)? No lights at all No power at all 4-way flashers do not work re-cleaned battery terminals tight battery neg to chassis ground 12.3 volts re tightened ground strap to chassis and tranny no power on fusebox under dash 3 vdc when key is off 0vdc when key is on thanks for your help |
Spoke |
Aug 19 2017, 02:27 PM
battery neg to chassis ground 12.3 volts You mean battery POS to ground? If battery NEG to chassis ground then there is no connection between battery NEG and chassis. What condition is the negative cable between battery and the chassis bolt above the battery? If nothing works, then it's likely the battery or wiring, not your ignition switch or the engine ground strap. Try this test: Turn lights or 4-ways on. Measure voltage across the TERMINALS of the battery, not the clamps. Touch the battery terminals. Then measure voltage from POS terminal to POS battery clamp. Then measure voltage from NEG terminal to NEG battery clamp. Here we're trying to find where the battery voltage starts and where it ends since it's not making it to any components. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:49 AM |
