electrical woes |
electrical woes |
Mike1981 |
Aug 19 2017, 12:03 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello everyone
Hoping to get some electrical help on my 72 It has a V8 in it but will not pass any power No buzzing of the fuelpump No dash lights No radio no horn nothing I pulled the ignition switch and tested it It was open until I turned the key and ohmed to almost 0 ohms When I released it open circuit Checked all wires in harness good Ohmed out every fuse in the panel below dash as well as a few in the rear of the car. Checked the ground strap (now a battery Cable) At first I was not getting continuity between the tranny bolt and the body Cleaned up the connection to the tranny as well as to the body ohms out to 2 ohms Checked the battery 12.5 volts Ohmed from neg terminal to chassis ground ohmed to 2-3 ohms It was running fine yesterday until i turned on the headlights while staring it then it died and I havent been able to get it to crank Any help would be appreciated thanks MIke |
Spoke |
Aug 19 2017, 03:16 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
OK, sounds like the battery terminals are tight.
No voltage at the fuse panel? The first 3 fuses from the center of the car outward are constant 12V. If not 12V, then some wiring issue is at play. How do the small wires look coming off the POS terminal? These wires go to the fuse panel. Before you go behind the fuse panel, disconnect the battery NEG terminal. Do NOT move the fuse panel with battery connected. Behind the fuse panel is a POS terminal block on the side of the chassis. Make sure this is tight. With the fuse panel down, make sure no connections touch anything. Connect NEG terminal to battery. Test the positive terminal block behind the fuse panel from terminal block to chassis. Should be 12V. |
Mike1981 |
Aug 19 2017, 03:35 PM
OK, sounds like the battery terminals are tight. No voltage at the fuse panel? The first 3 fuses from the center of the car outward are constant 12V. If not 12V, then some wiring issue is at play. How do the small wires look coming off the POS terminal? These wires go to the fuse panel. Before you go behind the fuse panel, disconnect the battery NEG terminal. Do NOT move the fuse panel with battery connected. Behind the fuse panel is a POS terminal block on the side of the chassis. Make sure this is tight. With the fuse panel down, make sure no connections touch anything. Connect NEG terminal to battery. Test the positive terminal block behind the fuse panel from terminal block to chassis. Should be 12V. Thanks I will re-check the smaller wires coming off the POS terminal at the battery. I will then disconnect the NEG terminal and drop the fuse panel and make the check you recommend thanks for your help. Mike |
Lo-Fi Version | Time is now: 19th May 2024 - 12:14 AM |
