electrical woes |
electrical woes |
Mike1981 |
Aug 19 2017, 12:03 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello everyone
Hoping to get some electrical help on my 72 It has a V8 in it but will not pass any power No buzzing of the fuelpump No dash lights No radio no horn nothing I pulled the ignition switch and tested it It was open until I turned the key and ohmed to almost 0 ohms When I released it open circuit Checked all wires in harness good Ohmed out every fuse in the panel below dash as well as a few in the rear of the car. Checked the ground strap (now a battery Cable) At first I was not getting continuity between the tranny bolt and the body Cleaned up the connection to the tranny as well as to the body ohms out to 2 ohms Checked the battery 12.5 volts Ohmed from neg terminal to chassis ground ohmed to 2-3 ohms It was running fine yesterday until i turned on the headlights while staring it then it died and I havent been able to get it to crank Any help would be appreciated thanks MIke |
Mike Bellis |
Aug 19 2017, 04:29 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Sounds like 2 of the 4 wires connected to the positive battery terminal are disconnected. 2 go to the alternator circuit and 2 go to the fuse panel/ignition switch.
Lo-Fi Version | Time is now: 18th May 2024 - 09:45 PM |
