Barn Find - What Did I Do?, Old Subie 6 Conversion |
7TPorsh |
Aug 21 2017, 10:38 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I got a little excited (IMG:style_emoticons/default/piratenanner.gif) ....I told a friend and he got excited (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) . Result?
We're the new owners of a (crustier than anticipated) (IMG:style_emoticons/default/dry.gif) 1975 with 2.7 Subaru /6. I think we bit off more than we can deal with, not sure. Bought the car based on a few pictures and bought remotely. Car has been sitting for about 3 years. Engine is a 2.7 Subaru ER JDM SOHC . Car threw one of the timing belts and owner says he parked it. Our intent was to get a decent car, fix it up a little drive it around for a few months; then maybe sell it and start again with a different car...friend is new to all this. SO as the car arrived and was put up on a lift at a friends shop; things unfold... This one is probably toast or too old to deal with. May be missing the ECU. Probably looking at needing a new engine; can keep Subaru if easy or go small bock chevy. I don't know anything about Subaru engines so not sure if this mount and adaptor will work. Also this cable shifter looks complicated. Just learned some of the car car work is documented here; maybe someone here knows the car....it's not in the database. My first inclination is to sell it as is to somebody with the means to turn it into a cool car. PM me if this is your dream project.... So looking for any advice in regards to "what would you do if you were me". Very limited on budget, space, spousal cooperation, etc. $.02 comment have validity so open to hear ideas. |
7TPorsh |
Aug 23 2017, 08:49 AM
I think we're going to throw a belt on it and crank it up see if it spins. If yes then get the car running. If not then looking at a new engine...
Anyone know if the newer engines use the same mounting points? |
mgp4591 |
Aug 23 2017, 09:13 AM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I think we're going to throw a belt on it and crank it up see if it spins. If yes then get the car running. If not then looking at a new engine... Anyone know if the newer engines use the same mounting points? I've never heard of a Subaru 2.7 - what's it out of? That would help you determine what you'd want to replace it with. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:20 AM |
