CV joints again, Can they be assembled wrong? |
gklinger |
May 18 2005, 06:11 PM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
So... I too am working to clean and relube my CV joints. Got one apart and cleaned, wear doesn't appear to be anything to be concerned about. I put it back together dry; went together fine. Now, there's no play at all between the inner and outer ball races. The cage moves in and out, the balls follow accordingly, but there is no movement at all in the relationship between the inner and outer parts. And so now I can't get the inner hub to swivel to get the damn thing back apart. WTF did I do now? Am I screwed? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
RustyWa |
May 18 2005, 11:28 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
If you put the joint together wrong, the way to get it apart again is you have to rotate the cage. The inner and outer will be locked together, so push on the cage.
v ^ v ^ v ^ |
Lo-Fi Version | Time is now: 20th May 2024 - 07:57 AM |
