CV joints again, Can they be assembled wrong? |
gklinger |
May 18 2005, 06:11 PM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
So... I too am working to clean and relube my CV joints. Got one apart and cleaned, wear doesn't appear to be anything to be concerned about. I put it back together dry; went together fine. Now, there's no play at all between the inner and outer ball races. The cage moves in and out, the balls follow accordingly, but there is no movement at all in the relationship between the inner and outer parts. And so now I can't get the inner hub to swivel to get the damn thing back apart. WTF did I do now? Am I screwed? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
brp914 |
May 18 2005, 09:15 PM
Unregistered |
well you answered your own question. Dang if 10 yrs ago I could work those things like a rubics cube w/o thinking about it. But had to do it again recently and ran into the problem you're having now. well, your post is 4hrs old so I guess you've discovered by now that if it goes together wrong you can wiggle it apart again. Hope you didn't put it back in the car like that. There is a right way and a wrong way. Or equal #'s of each. btw, cv's apparently are nla so treat 'em right.
Lo-Fi Version | Time is now: 9th May 2024 - 08:26 PM |
