Pedal set improvements- Now available in limited quantity., Clutch pedal shaft with ball bearing vs bushing |
bdstone914 |
Aug 27 2017, 10:11 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Out of the couple hundred pedal set I have rebuilt it is obvious the smallest bushings were out the most. The one in the clutch arm often wears completely through an starts wearing the arm itself. This happens with both the plastic and bronze bushings. It is a bigger problem on later 911's as they use a longer arms and have stringer pressure plates that accelerates the wear. And for some 911 the clutch shaft is NLA. Thank you Porsche.
I have made a prototype arm that uses a ball bearing to replace the bushing. I have now found a 17mm x 6mm x 6mm skate board bearing that will work. I have measured the pressure to depress the clutch and calculated the pressure on the bearing is about 25-50 lbs. The bearing are rated for over 500 lb so it should never fail. I have also toyed with the idea of replacing the clevis pin with a pull type spring loaded ball stainless steel pin. The clevis pins are hard to remove when they wear and there is little to grip to pull them out. The plan is to make new clutch shaft out of a heat treatable steel with the ball bearing design. Considering stainless for the shaft as the pedal sets often rust badly internally. The arm portion would be made straight eliminating the dog leg to the arm. A Delrin spacer that is used on 911's would be used to on the shaft to take up the distance of the offset of the original part. The distance C-C from the shaft to the bearing center could be changed to application with stiffer clutches ( like V8's ) Porsche varied this dimension starting with the SWB cars and made them longer up through the SC's. A shorter arm would give more clutch pedal modulation. I used to weld up the elongated worn hole and reshape ti round. PITA. The the cost for a new arm with a bearing looks to be in the $20 range. Attached thumbnail(s) |
turnaround89 |
Aug 27 2017, 10:42 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Id love to try this out on my subaru conversion. Not a bad price either. Any idea when they'll be available?
Keep up the great work |
Krieger |
Aug 27 2017, 10:47 PM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Nice work Bruce!
bdstone914 |
Aug 27 2017, 10:48 PM
Matty900 |
Aug 28 2017, 01:03 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/first.gif) Nice work Bruce!
michael7810 |
Aug 28 2017, 06:31 AM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Excellent work. Having you rebuild my pedals is on my long term list of stuff to do...not sure when but it will happen. Thanks for your support to the community.
mgp4591 |
Aug 28 2017, 08:26 AM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
You got the idea from playing with a Fidget Spinner, right?? (IMG:style_emoticons/default/w00t.gif)
mb911 |
Aug 28 2017, 08:37 AM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I want one..
bdstone914 |
Aug 28 2017, 08:55 AM
I told my grandson it was a figet spinner. Now he want me to make one for him. |
Aug 28 2017, 09:27 AM
Bruce, as soon as you make some, I'm a buyer. Thanks!
I'll also buy one with the longer clutch lever for my 915 conversion. |
bdstone914 |
Aug 28 2017, 09:55 AM
IronHillRestorations |
Aug 28 2017, 10:14 AM
DRPHIL914 |
Aug 28 2017, 10:20 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
an excellent improvement and solution to a common problem! (IMG:style_emoticons/default/drunk.gif)
I have a pedal set that id like to put one in, so one for me for sure! |
andys |
Aug 28 2017, 11:35 AM
Bruce,
Nice work! Did you look at the clevis with the spring retainer available from McMaster-Carr? Andys |
bdstone914 |
Aug 28 2017, 01:34 PM
Bruce, Nice work! Did you look at the clevis with the spring retainer available from McMaster-Carr? Andys No, but that is like the original one that is hard to remove it it is worn. I it is used with the bearing it should not were either way. I think it would be easier to have a straight pull pin. |
Elliot Cannon |
Aug 28 2017, 02:19 PM
Nice improvement Bruce. Put me down for one.
Kansas 914 |
Aug 28 2017, 02:21 PM
Nice improvement Bruce. Put me down for one. (IMG:style_emoticons/default/agree.gif) I need at least one - assembly is commencing on the Willow car now that the flared car is finished. |
whitetwinturbo |
Aug 28 2017, 09:14 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Bruce, we are not worthy... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
.........I want for my v8 (IMG:style_emoticons/default/wub.gif) |
euro911 |
Aug 28 2017, 09:40 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Nice innovative thinking, Bruce (IMG:style_emoticons/default/beerchug.gif)
I had to go with a different size bushing when I changed to the hydraulic system. I'll measure the bushing's ID, but also wondering if there's a possibility of sourcing a bearing with the correct ID I'll need. (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Aug 29 2017, 09:31 AM
OK Bruce, get off the computer and get to work on these. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 26th April 2024 - 12:09 AM |
