Pedal set improvements- Now available in limited quantity., Clutch pedal shaft with ball bearing vs bushing |
malcolm2 |
Aug 29 2017, 09:46 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
What about the offset? Is that what the nylon spacer bush is doing for you? and it is OK with the greasy spring? Can you assemble yours and show us the finished product?
I am not from Missouri, but I can fully understand if you "show me". |
amfab |
Aug 29 2017, 03:37 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
I haven't even installed the rebuilt one from you and you are making improvements. Apparently, I need to work faster.
-Andrew |
bdstone914 |
Aug 29 2017, 07:08 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I haven't even installed the rebuilt one from you and you are making improvements. Apparently, I need to work faster. -Andrew You can always upgrade. (IMG:style_emoticons/default/poke.gif) |
914forme |
Aug 29 2017, 07:39 PM
Looks like a deal to me
bdstone914 |
Oct 20 2017, 09:24 PM
I have five shafts available at this time. I am contacting those who expressed interest. I will be doing another batch soon as there were five people who said they wanted one. MB 911 sent me his pedal set and his is built.
Elliot Mepstein, will need a customer one, Have two made an need to assemble a set to make sure everything is right. Phillip W whitetwinturbo I decided to go with black oxide as a finish. Zinc plating is thicker and often causes assemble problems. Cost will be $50 for a finished shaft with bearing, spacer (needed as it is a straight arm ) , roll pin and spring loaded clevis pin. Price is $50 plus shipping. If you want a pedal set rebuilt with the impreved shaft the cost is $250. Attached thumbnail(s) |
porschetub |
Oct 20 2017, 11:53 PM
worn |
Oct 21 2017, 04:18 AM
can't remember Group: Members Posts: 3,152 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The part I really like is the new Clovis pin. It isn't as though you have a lot of space to work in when hooking up the clutch cable.
BK911 |
Oct 21 2017, 06:47 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
mb911 |
Oct 21 2017, 07:27 AM
914 Guru Group: Members Posts: 6,829 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
rgolia |
Oct 21 2017, 08:22 AM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Bruce,
I would like a pedal set rebuilt. What is the process? |
bdstone914 |
Oct 21 2017, 08:49 AM
MB 911 sent me his pedal set and his is built. Sounds like a lucky guy! Heard one may be heading to TN too!!! Not this Mb911 so maybe a mix up?.. I redid my own but would be interested in this upgrade. Sorry, I get you two mixed up. it is MK 911. |
bdstone914 |
Oct 21 2017, 08:51 AM
djway |
Oct 23 2017, 09:14 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Im in
bdstone914 |
Oct 23 2017, 09:15 PM
914work |
Oct 23 2017, 09:17 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Bruce if you still have stock Ill take one.
db9146 |
Oct 24 2017, 06:01 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Hi Bruce,
I've replaced my bushing in the last couple of years but for this mod, I'll go back in. Please let me know when you have another arm,pin, bearing, kit. Thx |
wndsrfr |
Oct 24 2017, 06:17 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
PM sent for one kit...
Lo-Fi Version | Time is now: 6th May 2024 - 06:53 PM |
