Ghetto engineering - Master cylinder style, I had to share |
Mikey914 |
Aug 31 2017, 11:43 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As may of you know we are in the process of producing master cylinders. Unlike some vendors with impeccably clean "Laboratory " complete with Periodic table. This is how we get things done.
Phase 1 We have a test bed that simulates braking, and are looking to see where our weak points are. We will put no less than 25,000 cycles on this part. This will take awhile as we can only get about 200 at a time without the motor heating up, but believe this to be a very rigorous test. Phase 2 If we make it to 25,000 we will start measuring output from the pressure lines. This will be thoroughly broken in system we will be testing, not just testing with air pressure. After the final round of testing we will tear it down to determine wear on critical components and examine the seals to see how well they have held up. If they show excessive wear we will look at improvements that may need to be made. Especially so if we don't make 25,000. My only serious concern is that the metal on the test stand may fatigue making us repair it before we hit 25,000 cycles. We are currently a little less than 5000 cycles. I thought I'd share this as many of you don't realize what we do behind the scenes t o actually make the parts we all need. https://youtu.be/UskyAeVAF9Y https://www.youtube.com/watch?v=UskyAeVAF9Y |
ConeDodger |
Sep 2 2017, 02:31 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
My experience with not just our 914 Master cylinder but in general is they don't fail because of use, they fail because of disuse. The sit with the piston in one place for long periods and it results in corrosion, particularly if the system isn't bled in a timely manner.
As for posting this in the Sandbox, someone's been watching too much porn... |
porschetub |
Sep 23 2017, 09:31 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My experience with not just our 914 Master cylinder but in general is they don't fail because of use, they fail because of disuse. The sit with the piston in one place for long periods and it results in corrosion, particularly if the system isn't bled in a timely manner. As for posting this in the Sandbox, someone's been watching too much porn... Not sure appears some (URO) last a shorter time,nothing wrong with this test IMO and nice to see someone doing it...appears some don't bother...did I mention that before (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:05 AM |
