Ghetto engineering - Master cylinder style, I had to share |
Mikey914 |
Aug 31 2017, 11:43 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
As may of you know we are in the process of producing master cylinders. Unlike some vendors with impeccably clean "Laboratory " complete with Periodic table. This is how we get things done.
Phase 1 We have a test bed that simulates braking, and are looking to see where our weak points are. We will put no less than 25,000 cycles on this part. This will take awhile as we can only get about 200 at a time without the motor heating up, but believe this to be a very rigorous test. Phase 2 If we make it to 25,000 we will start measuring output from the pressure lines. This will be thoroughly broken in system we will be testing, not just testing with air pressure. After the final round of testing we will tear it down to determine wear on critical components and examine the seals to see how well they have held up. If they show excessive wear we will look at improvements that may need to be made. Especially so if we don't make 25,000. My only serious concern is that the metal on the test stand may fatigue making us repair it before we hit 25,000 cycles. We are currently a little less than 5000 cycles. I thought I'd share this as many of you don't realize what we do behind the scenes t o actually make the parts we all need. https://youtu.be/UskyAeVAF9Y https://www.youtube.com/watch?v=UskyAeVAF9Y |
Mikey914 |
Sep 23 2017, 10:08 PM
Broke somewhere around 10k. The weld broke. Kept cycling but not a full pressure as the plate flexed at the weld.
The EURO one I put on my car lasted 5 cycles. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:39 AM |
