Interior light, My next electrical gremlin |
tomh |
Sep 3 2017, 11:54 AM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
So now my next electrical problem is my interior light on the back pad between the seats. The light and fixture are brand new and the wires seem to be fine.I tested the light out side of the car and it does work.I grounded it with a pig tail and it still wouldn't light so I checked it with a meter and it doesn't seem to have much power if any it think I got a reading of a couple of volts but still not sure about that. It will not light on any of the switch positions. Could it be the door switches? What other electrical items are on that circuit. Which fuse in the stock fuse block is it?
Thanks all! |
rgalla9146 |
Sep 3 2017, 12:59 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
So now my next electrical problem is my interior light on the back pad between the seats. The light and fixture are brand new and the wires seem to be fine.I tested the light out side of the car and it does work.I grounded it with a pig tail and it still wouldn't light so I checked it with a meter and it doesn't seem to have much power if any it think I got a reading of a couple of volts but still not sure about that. It will not light on any of the switch positions. Could it be the door switches? What other electrical items are on that circuit. Which fuse in the stock fuse block is it? Thanks all! Remove each door switch and clean the pointed connection and the 'v' shape receiver with an Xacto knife or a razor blade. Slide the push-on connectors on and off their blades repeatedly to improve connection. As I recall the switches are all on the ground side of the lamp. The power wire is less than 12v ? .... (the green wire) check that at the fuse box connection. |
ConeDodger |
Sep 3 2017, 02:58 PM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
One of the first things any 914 owner should do when they get their car is chase down and clean the dozen or so grounds. Makes a bunch of gremlins go away! (IMG:style_emoticons/default/evilgrin.gif)
914_teener |
Sep 3 2017, 03:34 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The door switches ground tje light.
Mine were just worn out. |
Matty900 |
Sep 3 2017, 03:53 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
One of the first things any 914 owner should do when they get their car is chase down and clean the dozen or so grounds. Makes a bunch of gremlins go away! (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/agree.gif) I use a dremel tool with a wire wheel brush on a flexible wand attachment to get off all the corrosion & or paint Attached thumbnail(s) |
Sep 3 2017, 03:58 PM
The power wire should have constant 12V. Check from it to a good ground, like the battery (-) terminal. If it's less than 12V, check the (+) side of the circuit for dirty or bad connections.
The ground side of the circuit is generally more likely to give trouble, so that should definitely be checked as well. --DD |
ConeDodger |
Sep 3 2017, 04:01 PM
One of the first things any 914 owner should do when they get their car is chase down and clean the dozen or so grounds. Makes a bunch of gremlins go away! (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/agree.gif) I use a dremel tool with a wire wheel brush on a flexible wand attachment to get off all the corrosion & or paint I believe Bowlsby has a map of 914 ground locations on his site... |
tomh |
Sep 3 2017, 05:39 PM
Both of the wires going to the fixture is black with stripes. One of the wires has a larger female connector and one is smaller. I'm assuming the smaller is the ground.
Sep 3 2017, 07:33 PM
There should be three wires. One black, one brown, one brown with a white stripe.
Sounds like someone has monkeyed with your wiring. You may want to pull the back pad out and see what has been done. --DD |
rgalla9146 |
Sep 3 2017, 08:44 PM
There should be three wires. One black, one brown, one brown with a white stripe. Sounds like someone has monkeyed with your wiring. You may want to pull the back pad out and see what has been done. --DD Right again Dave. When I said 'green wire' I was confused with the wires for the rear defog. |
raynekat |
Sep 3 2017, 08:45 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Often times the door contact switches will be bad.
Especially the early ones that have 4 terminals. Both were bad on my 71 and I went through about a half a dozen of supposed good switches before I found a set that work. If the door switch is bad, there is no way that interior light is going to work correctly. And it's true; you need a full 12V+ for that light to light up. |
whitetwinturbo |
Sep 4 2017, 01:33 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
What is link to all the "ground" locations (IMG:style_emoticons/default/beer.gif) ?
tomh |
Sep 4 2017, 06:45 PM
So I removed the back pad and the only wires long enough to reach the light are all brown with white stripes. There is a connector with 3 wires attached and a connector with 1 wire then there is one with a smaller connector. All the other wires down there are the seat and seat belt stuff. I tried both of the connectors and still no power to the light. Both of the door switches seem ok with good connections and a strong spring also I did clean the "v" contact as best I could.
Am I missing something here? |
raynekat |
Sep 4 2017, 09:53 PM
When you say the switch has good connections, what do you mean?
With the button or spring out, dId you check each pair of pins for continuity with a multimeter? That is the only way to really know. With the button in or spring compressed, the multimeter should show lack of continuity across each pair of pins. These switches really do fail after a number of years and bazillions of times opening and closing the doors. |
dangrouche |
Sep 4 2017, 10:10 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
here's Bowlsby's diagram Attached thumbnail(s) |
tomh |
Sep 4 2017, 10:37 PM
I'll test the switches and see what I come up with.
carcus |
Sep 4 2017, 10:55 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
I have the same problem as well. But I have plenty of time to fix it. Most of my OEM wiring was dry rotted. Mine seems to be the door switch. The middle setting will keep the light on but will not go on with the door open.
tomh |
Sep 5 2017, 08:12 AM
My problem is power to the light, weather the switch is good or not I still should have 12 volts to one of the wires,all the switches do is ground it to make it light up that's why my switches probably are not my problem.
914_teener |
Sep 5 2017, 09:53 AM
So how did you test it then? That would be helpful to know.
You should have 12V at the black red striped wire. Assuming the car is a 73. The power comes off the fused side of fuse 11. Test the wire at the end for 12v against a known good ground. If you find 12v there then the power feed is good. If not then the wire is suspect if the fuse terminal checks at 12V. Make sure the connections are clean. Hope this helps. |
Sep 5 2017, 09:57 AM
Find the solid brown wire, and find the black (or black/red) wire. The latter has a constant +12V and is how the light gets powered.
--DD |
Lo-Fi Version | Time is now: 21st May 2024 - 02:22 AM |
