Refurbishing a rear reflector.......ar, ar, ar, Say that three times, thar maties |
db9146 |
May 19 2005, 07:21 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Need some help, if you please......
I have a rear reflector that needs to have the rear repainted. The paint is gray facing away from the reflector, but is it appears to be "chrome" on the side against the back reflector. Is this correct? What has anyone used in the past to refurbish the backside of the reflector? Did you use anything to prep the back side? Thanks |
xsboost90 |
May 19 2005, 08:46 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
if you could get the old stuff off and chrome paint it then do grey over that, should look stock. Or..touch up?
Lo-Fi Version | Time is now: 18th May 2024 - 03:19 PM |
