OT water in compressor, how to minimize/eliminate this? |
914 RZ-1 |
Sep 9 2017, 06:16 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
If anyone has any experience with air compressors, I'd like some help/advice regarding the following:
I have a 30 gallon Craftsman compressor (built in 2008). 8.6/6.4 CFM @ 40/90 psi. I have a moisture filter before the hose hook-up. 1. RUSTY WATER IN THE TANK When I drain the tank, there is always rusty water, maybe 1/4 cup or so. I know this is normal, but how much is supposed to come out? Is there an standard/typical amount that is normal? 2. WATER IN THE HOSE I also get air in the hose that comes out whenever I use air tools. I get a few drops every few minutes. When I bleed the moisture filter, no moisture comes out. 3. IN-LINE FILTER I'm thinking of getting another in-line moisture filter. I will be painting some parts soon and want to make sure that I don't spray water with the paint. What do I look for in a decent, in-line moisture filter? Thanks! |
Lo-Fi Version | Time is now: 19th May 2024 - 04:31 AM |
