2004 audi wont start, 2004 cylinder pressure |
joel86 |
Sep 10 2017, 06:08 AM
Newbie Group: Members Posts: 1 Joined: 10-September 17 From: usa Member No.: 21,421 Region Association: North East States |
i have a 2004 audi a4 1.8t drove to work then after work went out wont start checked for gas good spark good checked timing belt good number 1 cylinder 190 number 2 cylinder 120 number 3 cylinder 110 and number 4 cylinder 130 and ideas
Sep 10 2017, 09:00 AM
Timing belt skipped a tooth or two?
Andyrew |
Sep 10 2017, 12:12 PM
Probably not. Likely some sensor. It'll still run a couple teeth off.
Check your crank position sensor. |
porschetub |
Sep 11 2017, 12:00 AM
Throws all the compression out cause the engine looses correct firing order,my BMW did the same but it had a "limp home" mode had the power of a scooter (IMG:style_emoticons/default/headbang.gif) .
Get the car scanned to isolate the problem otherwise you will be chasing your tail and spending $$$. My same car (Audi) crapped the MAF sensor ,didn't code correctly so cleaned it,got 2 months and it went (IMG:style_emoticons/default/stromberg.gif) replaced it and sold the car still going with 200KMs on it ...very strong little engines its just the all the sh#t that hangs off them go's wrong (IMG:style_emoticons/default/sad.gif) . |
Lo-Fi Version | Time is now: 15th May 2024 - 11:57 PM |
